Projects 1956 Sunliner Continuous Upgrades
Discussion in 'The Hokey Ass Message Board' started by Eric16, Sep 27, 2022.
  1. Eric16
    Eric16
    Hello H.A.M.B. family!
    This will be my 2nd dive into the world of 50's Fords/Y Blocks. My first car of this era was a 1956 Ford Victoria. My wife and I loved that car so much, we decided we wanted the convertible! As always, I appreciate any tips or advice from more experienced members out there.
    I found this car online. It is a nut and bolt restoration that was done by an older gentleman who had p***ed away. The car sat for 2 years and was sold. I bought the car with 250 miles on the restoration. It's got:
    312, two barrel Holley, Ford-O-Matic
    Power steering, Manual drum brakes, power top, bias tires
    Like any restoration, it has some bugs to be worked out. Right now, the biggest bug is the transmission leak. Just sitting over night, it had created a small stream in my garage running under half the car. Brakes aren't doing a great job stopping the car. Speedometer and water temp gauges aren't working.
    My over all goal with the car is to keep it factory appearing, but make it safer and more practial for family use and longer cruises.
    A couple of things I did to the Victoria and I liked were:
    KYB Gas-a-just shocks
    Stop em and drop em Granada disc brake conversion
    Gl*** pack mufflers!
    Car seat anchors
    Things I'd also like to do are:
    Diamond Back radials
    4 Barrel intake and Holley Sniper EFI
    Upgraded sway bars
    Air Conditioning
    Remove continental kit
    For now, here are a few pictures, and I'll post updates and quetions as I go!
    20220917_105848.jpg 20220917_105857.jpg 20220917_105905.jpg 20220917_105915.jpg 20220917_105923.jpg 20220917_105933.jpg 20220917_105940.jpg 20220917_110001.jpg 20220917_110008.jpg 20220917_110013.jpg 20220917_110413.jpg 20220917_110419.jpg
  2. John Stimac
    John Stimac
    Pretty Sum*****
  3. 03GMCSonoma
    03GMCSonoma
    Damn that looks great!
  4. 40FORDPU
    40FORDPU
    It's a beauty!
  5. Okie Pete
    Okie Pete
    Wow very nice
  6. wicarnut
    wicarnut
    Beautiful car, Enjoy !
  7. Dos Cincos
    Dos Cincos
    Nice looking start and a great plan for her moving forward. Fix the little things and drive the wheels off it.
  8. Just needs dropped in the dirt.
    Cool ride
    hotrodjack33 likes this.
  9. guthriesmith
    guthriesmith
    Looks like a very nice car! I would lower it and drive it for the most part. I ended up just using a factory 57 4-barrel intake on my 56 to be able to run a normal square bore carburetor. Pretty sure that is the biggest improvement over stock for driveability I did. Also, I agree with pulling the continental kit off.
  10. SPEC
    SPEC
    Great Ride!
  11. hotrodjack33
    hotrodjack33
    That's a gorgeous car...and I have to agree on losing the continental kit. I could never understand why FoMoCo kits had the full bumper extension panel and all that extra acreage. I hate to say it, but GM had a "Better Idea";)
    lothiandon1940, 1949*john and bob b. like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I see you are fairly new here and maybe don't know. EFI is off topic here. so please do not mention that as you go forward. great looking car by the way, have fun with it!!
  13. ffr1222k
    ffr1222k
    If you find you need to replace the speedometer I do have a working unit free for the shipping.
    Message sent
    lothiandon1940 likes this.
  14. abonecollector
    abonecollector
    clean as a whistle!!
  15. HOTRODPRIMER
    HOTRODPRIMER
    That car stands tall, have fun with it. HRP
  16. Wanderlust
    Wanderlust
    Beautiful car! Just a word to the wise, if you’re into junkyard searches don’t forget to pop the hood on larger trucks, that’s how I found my 4 barrel manifold
  17. Malcolm
    Malcolm
    from Nebraska
    Nice car! I totally agree with the continental kit removal. Another vote here for the '57 'B' 4-barrel intake. Running a carb would keep things more simple... No wiring, electric fuel pump, etc. to worry about.
  18. Ralphies54
    Ralphies54
    You lucky som*****, Beauuuuutiful .
  19. miker98038
    miker98038
    That’s a great looking car, and a great plan. Having done an unmentionable intake on my 312/stroked 320 Yblock, I’d go with a carb. Either the 57 manifold or a Blue Thunder or a Mummert. So,e of the newly available annular booster style carbs seem to provide really great street performance without the expense and trouble of other alternatives. Or even a 4100 Autolite.
  20. jaracer
    jaracer
    Someone mentioned that all Ford-O-Matics leak. I've had one in my 57 T-Bird for the last 26 years and it doesn't leak. However, my definition of a leak is leaving a puddle. Cars of the 50's do mark their spots. I've never worried about a spot on the floor here or there. That's what all those cardboard boxes are for from all the parts you order.
  21. I agree with those above cheering your choice of a Sunliner for your new ride. Enjoy!
  22. Eric16
    Eric16
    Thanks for all the great replies! Always good to have people agree with your plan!
    First thing to check off the list are power disc brakes! Got another kit from NASCAR Dave at Drop' Em & Stop' Em. Power Granada disc brakes with a 1.5 in drop. As usual, the kit was amazing and includes absolutely everything you need except brake fluid and wheel bearing grease! Very clear instructions, and at any point you have a question, he always picks up and is very helpful!
    scotty t and Dos Cincos like this.
  23. Eric16
    Eric16
    First step was to throw a coat of cast iron gray paint on the master cylinder to avoid any surface rust.
    After that, the old drum brakes came off. Pretty easy on a restored car! Step by step, the new spindles and brakes went on. Last step is to bolt in the new power brake booster and master cylinder and connect a couple of new lines to the rest of the stock system! I'd highly recommend this kit to anyone looking to upgrade their brakes!
    20220926_222406.jpg 20220927_153447.jpg 20220927_162309.jpg 20220927_172159.jpg 20220927_172651.jpg 20220927_173452.jpg 20220927_181544.jpg 20220928_205704.jpg
  24. Eric16
    Eric16
    Currently just the 1.5 in drop in the front with the brake swap. We'll see if that gets me closer to level. Once the kit comes off, I'll do my best to have it sit level. I dropped my Victoria 2.5 inches which looked great, but this one will be slightly more "stock"
    guthriesmith likes this.
  25. Eric16
    Eric16
    The kit isn't the worst looking thing around, and it is iconic on the 50's cars. But I think the back of a 56 Ford looks so good, the kit doesn't add much too it.
  26. Eric16
    Eric16
    This one currently creates a small stream on my floor over night. The car did sit for a couple years after the restoration, so I may just try and drive it a bit to see if it gets better on its own.
  27. phat rat
    phat rat
    I never cared for those, I consider them a 1/2 ***ed continental kit. IMHO full width or not at all. Back in 60 a friend bought a 60 Impala with full width continental kit from the dealer
  28. okiedokie
    okiedokie
    from Ok
    Nice job on the pictures, I never have the patience to take em.
  29. KULTULZ
    KULTULZ
    That is an unbelievable restoration. I cannot imagine the time, love and cost that went into it. And then the man p***ed.
    Anywho, if you decide to go with an ECZ-B intake and 4V, most likely the DIST is still a LOAD-O-MATIC and will need to be upgraded to a 57/ DUAL ADVANCE (no CHI-COM HEI please).
    I would surely like to know what that SPARE WHEEL CARRIER is going to sell for. It appears to be complete OEM w/ the rear face bar exhaust outlets.
    If you could, can you post (within this saved thread please) what you get for it.
    GordonC likes this.
  30. 19Fordy
    19Fordy
    Your 56 is simply beautiful. Congratulations to you and your wife.
