1957 Buick 364 Nailhead
Discussion in 'Parts For Sale' started by class 'A', Jul 6, 2022.
  1. class 'A'
    class 'A'
    from Casper,Wyo
    City: Casper
    State: Wyoming
    Price: 2000 OBO
    It's with great remorse I've decided to let this project go.
    1957 Buick 364 Nailhead- Project engine
    Needs valve springs, pushrods and balancing.
    Block is machined and ready for ***embly
    New Egge Pistons
    New rebuild rocker shafts
    Stock Tin
    Custom Comp Cam matched to ported heads
    Heads are ported and polished, flow tested and set up with smaller diameter valves for flow and spring options
    Crank is ground and ready
    Stock flexplate
    Connecting rods are rebuilt and coated
    Two gasket sets
    New Timing set
    *Rebuilt 57 date code carb including core. Has the starter switch and a core carb.
    Buick 4Bbl intake
    Need to finish the valve train, balance it for your transmission and put it together.
    Should make Good Power.
    I've got over 3K invested in parts alone.
    Asking $2000 OBO to a good home. Open to standard hot rod guy trades.
    If you have any questions; just ask.
      335.7 KB
      372.2 KB
      242.9 KB
      283.4 KB
      284.5 KB
      270.1 KB
      460.1 KB
  2. class 'A'
    class 'A'
    from Casper,Wyo
