Customs 1957 Cadillac engine swap question
Discussion in 'The Hokey Ass Message Board' started by logic2, Apr 29, 2017.
  1. logic2
    logic2
    Just acquired a 57 Caddy Eldand the original block (365 ci) is locked up & missing the intake/carbs.
    Until I can remove and tear down the motor to see the damage, rust, etc...and know if it's repairable,
    I'd like to hear what others have used for engine /****** replacement.
    I've read several posts about people having problems swapping in BBC, but curious if SBC also requires significant modifications ?
    Thanks in Advance
    Mike
  2. rc57
    rc57
    My dad has a 365 w/single 4bbl engine/trans combo he pulled out of his '57 62 series. Drove it home and pulled it to put in a built 500/400TH. He's in Arkansas, if you have any interest I can PM you his phone and you can talk to him about it.
    Rich
    clunker, logic2 and falconsprint63 like this.
  3. Rocky
    Rocky
    Classified Editor
    A 57 Eldo is a valuable car. Installing a single 4 barrel 365 will dimish it'd value a little but installing a chevy engine will drop it's value a LOT! I have absolutely no problem with a small block chevy motor but it has no place in a 57 Eldorado. Good luck with the original engine...hope it's usable.
    warbird1, clunker, Moriarity and 3 others like this.
  4. I agree with Rocky. Be sure to check what the car is worth to a collector. It might be worthwhile to spend a little extra and have the original engine rebuilt. Go SLOW on your decision. I am sure there is a Cadillac club with a web site (I was on it several years ago when looking for an Allante). Does anyone know the production figure for that style?
    Charlie Stephens
    logic2 likes this.
  5. greybeard360
    greybeard360
    Yup..... Get the original motor fixed and find the correct intake and carbs for it. You will have a gold mine on your hands. Of course, it may take a silver mine to do it right [emoji16]
    Sent from my Moto G Play using The H.A.M.B. mobile app
    clunker, Truck64 and Max Gearhead like this.
  6. Caddystew
    Caddystew
    from East Texas
    I just completed swapping in a 1970 Cadillac 500 into my 57. It is a lot of work but can be done. Biggest issue is saying enough is enough and let's get back on the road. PM me and we can discuss what it takes.
    clunker and 302GMC like this.
  7. khead47
    khead47
    Dual quads and air cleaner will probably gonna cost you more than the car- but will be worth it in the long run.
    logic2 likes this.
  8. logic2
    logic2
    Thanks for all the feedback and suggestions.
    Hopefully the block / crank will be useable.
    Thanks again
    Mike
  9. clunker
    clunker
    from Boston MA
    Ya, that's a '57 Eldorado Seville, not some Sedan or Coupe. I would do some research before you take a torch to it to install some LS or SBC thing.
    If you're itching for Chevy power, you might do better to sell the Eldo and buy a roached out Coupe Deville and do your 350/350, and keep the change.
    If the seized motor is numbers matching, you could take the existing motor out and store it, it wouldn't be that tough to find a running 390, the 390 should bolt right up to hydramatic, sometimes you need the newer bell housing for the starter to clear the motor's oil pan. The Jetaway isn't that hard to rebuild, if it needs freshening. This way you're not cutting up a '57 Eldo, and the **** collector who buys it from you in 10 years for $70,000 can have the matching engine block. Just a thought, but I would try to rebuild the original motor and just run a single four barrel until you come across a dual quad, I came across one on Ebay with orignial Rochesters for $300
    Just a thought
    logic2 likes this.
  10. dan c
    dan c
    i've posted this before; maybe bears repeating. from about 45 years ago... Scan0038.jpg
  11. clunker
    clunker
    from Boston MA
    I remember seeing that before. Good article. A lot of good info for that option on www. Cadillacpower.com
    This would be a really excellent old hamb thread for the OP to read:
    https://www.jalopyjournal.com/forum...engine-******-swap-need-some-guidance.651545/
    A lot of people chime in with their own real world experience doing exactly what he is contemplating.
    I think a lot of peoples' hesitation isn't about reluctance to do an engine swap in general, I'm pretty sure we are all for hot rodding an old car. But if you're into old Caddies, especially a 57-58, the Eldorado is a pretty special beast. Even though it's not a Brougham, this is a really cool car, GM went nuts on the Eldorados in '57-58. After that, they weren't all that much different from the rest of the line up (well except for the Pininfarinas in 59-60, but that's a different story)
    I think either way, the OP wins. Awesome car.
    dan c likes this.
  12. Steffen Jobst
    Steffen Jobst
  13. Steffen Jobst
    Steffen Jobst
    logic2 likes this.
