1957 chevrolet pick up
Discussion in 'The Hokey Ass Message Board' started by gerry miller, Dec 10, 2013.
  1. gerry miller
    gerry miller
    My 57 is totally stock outside except widened rear fenders. I do have a Durango clip and Durango rear end in it and Chrysler master under the floor. I was wondering if anyone here could tell me if the 2002 Durango master has built in residual valves???? My first post was deleted. Kind of be nice to know why? I guess I may have put it in the wrong cl***. I 'm sorry if I did. Bled the brakes and have good pedal even without booster hooked up.:D
  2. squirrel
    Usually it's a good idea to also use the combination valve from the donor vehicle when doing a swap like that. My guess is the residual valves would be in the combination valve, but that's only a guess based on how older GMs were built.
    Maybe there isn't enough "traditional" in your build to make it past the censors? just a guess
  3. rusty1
    rusty1
    you mite have a good pedal, but since you're not driving it; you won't know if the brakes are working correctly?
  4. junkyardjeff
    junkyardjeff
    How did the Durango clip fit,if it has the correct width I will have to remember it as there are a few in the junkyards around here.
  5. gerry miller
    gerry miller
    Jeff, 2 wheel drive Durango clip was OK width wise but it is a hell of a lot more work than a Camaro. The track is wider. I read Lux Blues instructions on the Camaro swap for general guidelines. Really would have rather used a Camaro clip. The rack and pinion steering is about the only plus.I may have a little problem on track width of front tires and fenders. They are close when turning. Also had to make a drop down frame section for the stock radiator and bumper mount section.I'll post some pics tomorrow.
    Gerry
  6. gerry miller
    gerry miller
    Jeff I had to make motor mounts so steering would go under them all in all more work than I wanted to do. Also used Dakota front springs. Durangos were way too stiff.
    305 oil pan from a pick up for dip stick , plugged old dipstick hole in block..305 exhaust to clear steering linkage.
    Gerry
