Front disc brakes with dropped spindles, Engine is a Blueprint Motores 383 with a dyno run sheet, long tube headers & 2 1/2-inch FloMaster X pipe exhaust, new clutch and TO bearing, Fresh Muncie 4 speed with comp plus shifter, chrome tilt column and 16 inch wheel, new TA radials on new 7 and 8 inch steel wheels. I see no rust anywhere and the floor is red oxide primer top and bottom. This is a fresh build and still needs some sorting out (as usual).
