Projects 1957 Styled Deuce Build Update
Discussion in 'Traditional Hot Rods' started by ziffer, Aug 3, 2014.
  1. ziffer
    ziffer
    from michigan
    Thanks for the concern. I already have a piece of 1inch wide 1/8 inch banding in the lip. Everything is then bolted into the curved "boomerang" supports that go to the support rail in the top of the cowl. We all need to keep safety in mind and we are all prone to overlook something.
  2. Keep updates coming
  3. 383deuce
    383deuce
    This is some good ****....Keep it coming
    robracer1 likes this.
  4. x77matt
    x77matt
    Russ- let's see the latest!!
  5. Rand Man
    Rand Man
    Yep, I'll follow this one.
  6. chop job
    chop job
    from Wisconsin
    Love this build
  7. 383deuce
    383deuce
    What is that 3 window Larry says about waiting............
  8. chop job
    chop job
    from Wisconsin
    Come on man what happened to this build?
  9. ziffer
    ziffer
    from michigan
    I know it has been a while since a post so I will try to get updates in etc over the next week or so. The following is a short update and more in depth stuff to follow.
    So the problem is that the accel. linkage is originally set up to go to the p*** side of the intake. I'm running an Offy intake with 97s and need to have the linkage go to the driver's side. The main problem is the slot where the pedal goes through the firewall is right next to the area where it kicks out so very little real estate. (I know some of you are saying you should have thought of this before paint, but I've done this on my 33 so I was not worried.)
    Get out your parts
    since this build is supposed to be 1955-1958 era correct I am using original parts and retaining the original "style" of engineering.
    The way the original worked is the shaft slipped through this sleeve and the end on the left kept everything from turning as it was captured in the semicircle cutout in the firewall cap. The right side rested in a socket to allow everything to pivot without moving left and right. I cut the end off the shaft and was going to work with it but it just was not a fit that I felt comfortable with.
    By welding up the cutout in the firewall cap I was able to drill a hole all the way through the cap providing support on both sides of the accelerator pedal arm. (The arm sticks through the firewall and the shaft slips through a loop on the end and they are pinned together.) Using some hinge pin bushings I now have a very precise way to hold the rotating shaft that will not wear out (while I'm alive).
    Test fit on the firewall
    Blasted and Primed
    Installed
    kiwijeff, AHotRod, elgringo71 and 2 others like this.
  10. chop job
    chop job
    from Wisconsin
  11. ziffer
    ziffer
    from michigan
  12. AHotRod
    AHotRod
    What a sweet Hot Rod your building..... I'll keep following along with ya.
  13. Barnmiester
    Barnmiester
    from wyoming
  14. Bugguts
    Bugguts
    Cool! Subscribed.
  15. ziffer
    ziffer
    from michigan
    couple of quick pics
    Dash mounted rear view mirror that posted earlier is installed DSC00959.JPG DSC00960.JPG
    Rear of car is done. I don't ever want to sand around another louver ..........until the next car.
    Tim_with_a_T and AHotRod like this.
