Technical 1959 apache build ( help )
Discussion in 'The Hokey Ass Message Board' started by Charlie1959Apache, Jul 11, 2023.
  1. trying to bring my 1959 chevy fleetside apache back to life. has the 235 straight 6 with 3 on the tree.
    having a problem with the gas tank building up a lot of pressure when trying to get it started. when i open the cap it ****s in a Burst of air. Any Ideas or tips?
    I have already put in
    New tank
    New Fuel Neck
    New lines from fuel pump to carb
    new sending unit
  2. Bleach
    Bleach
    Sounds like the gas cap isn’t venting. Try a vented cap.
    anthony myrick and Budget36 like this.
  3. rusty valley
    rusty valley
    pressure and vacuum are two different things. Watcha got goin on there ?
    tractorguy likes this.
  4. squirrel
    You can leave the cap loose or off to start the truck.
    If you want help figuring out why it won't start, we'd probably need a lot more information....as it's pretty much unheard of for a gas cap to prevent an engine starting. Unless it already started, ran for a while, and stopped running due to fuel starvation.
  5. old school rodder
    old school rodder
    When I did my 59 Apache, I took bought a new fuel tank with cap. My cap did not vent at all, building pressure when the gas warmed and expanded, vacuum when it cooled. Bought a new vented cap, problem gone. It would build so much pressure gas was forced into the bowls causing significant fuel leaks, flooding, not running.
    There is a way to modify your cap to make it act vented to at least see if that's the problem. Searching will give you ideas.
