Projects 1959 Chevrolet Apache 3100 - Build Thread.
Discussion in 'The Hokey Ass Message Board' started by SanDiegoJoe, Jan 28, 2010.
  1. BloodyKnuckles
    BloodyKnuckles
    I ran those exact tires. You'll hear some negative thoughts but understand they are a fine tire. I put 30,000 on mine, been all over the country and driven through some nasty weather. I never had the front end aligned after I wacked 2 wraps off my coils and drove the poor Plymouth hard, very hard.
    In the beginning they tracked very well but at about 28,000 they started to wander a bit.
    What I'm trying to say is that you will be pleased.
    BTW....I totally dig the **** out of your truck!
    ******Knuckles
  2. Flingdingo
    Flingdingo
    Sweet. That's the kind of weekend project where you stand back, look at it and think - Now we're getting somewhere!
  3. SanDiegoJoe
    SanDiegoJoe
    They drive pretty damn good, I hope they last me 30,000 miles!
    Small, attainable goals.
    Of course, Now the right turn signal blinker light doesn't light. The blinker works, but I'm be gonna spending alot of time going around the world to right.
    - Joe
  4. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    That's awesome Joe! Truck is really coming along!
  5. SanDiegoJoe
    SanDiegoJoe
    Yesterday I stopped by the shop of my friend that re-built my carb (sorry Turd, I didn't tackle that one on my own. Your tech article still rocks). There were still some issues with the 1BBL that makes it only run nicely with the choke a little out.
    I asked him about swapping to an electric choke. It requires a different carb, and he had one on the shelf!
    So for the price of a re-build kit, he is going to hook me up with a rebuilt 1bbl with the electric choke. I'll have to install it myself, but he is going to tune it for me.
    I still think that Carburetor is a French work that roughly translates to "Joe, don't **** with it."
    The hole in the dash that is left from the manual choke is going to get filled with the extra headlight switch that I have. I'll use it to switch the amp for my MP3 player.
    - Joe
  6. terd ferguson
    terd ferguson
    I saw your truck in that other '57 thread. Looking good! Glad you're getting your carb sorted. If you're keeping the old one, you should try and rebuild it anyway. You'll have a backup piece.
  7. SanDiegoJoe
    SanDiegoJoe
    The carb is going to the rebuilder. I think I have a spare, though. It is always nice to have a backup piece on the side.
  8. SanDiegoJoe
    SanDiegoJoe
    Not much has changed on my pickup... except a trip on a tow truck 'cause my engine seized.
    Most likely my fault, I used an oil filter that got wet last time I changed the oil.
    Nothing like turning a $14 part into a $1400 repair.
    Oh well. I'll have it back in 3 weeks, the head had been rebuilt, I guess the bottom of the 235 was jealous.
    - Joe
  9. ironandsteele
    ironandsteele
    love your truck man. bummer about the motor. oh well, when you get it all back together it will be like a whole new truck.
  10. terd ferguson
    terd ferguson
    Joe, sorry about the engine! Even though the cir***stances ****, look at the bright side. You'll have a nice new, fresh, clean, reliable engine! Time to paint under the hood while its out!!! :D
  11. 57 3100
    57 3100
    bummer joe....
    can you please explain a wet oil filter and how that messed your motor up ?
    water got inside and saturated the paper filters ?
    thanks and good luck..
    leonard
  12. SanDiegoJoe
    SanDiegoJoe
    I'm not sure actually - it's just the only thing I can think of that I did wrong! There is no way to vent the g***es on my block, the vent tube was capped with a freeze plug, so maybe that mixed with the steam from the water caused it to seize. I do know that it was not the pistons - must have been the crank.
    I scored a complete 235 from a buddy for $80 that will be a good rebuilder. I decided not to spend the $$ on the old one to find out what actually went wrong.
    Yeah, Terd & shooter, I am looking at that as being a plus. I had a shot at another 235 that I could slide on the total rebuild on but let it p*** (not worth saving $400 of so and still having just a "fresh" engine).
    - Joe
  13. terd ferguson
    terd ferguson
    Joe,
    Too late now, but you could always drill that freeze plug and put a rubber grommet in it with a pcv valve. Have it vent to the atmosphere like a road draft tube or run a vacuum line back to the intake or carb.
  14. 57 3100
    57 3100
    thanks for the explanation joe..... good luck....
    leonard
  15. 1958apache
    1958apache
    Your truck looks great.
    Are those L78's the 4" wide whites? I see they are the coker cl***ics. How do you like them? They look awesome. How's it drive? I'm about to pull the trigger on these same tires. Do you have anymore photos with the new tires?
    Thanks,
    Chad
  16. SanDiegoJoe
    SanDiegoJoe
    Thanks man.
    They are the 3" wide whites, and they drive EXCELLENT. The pickup is off the road right now.. the engine seized and it's getting the rebuilt 235 installed as I type.
    The chucks are still running nicely, too btw.
    More pix soon!
    - Joe
  17. terd ferguson
    terd ferguson
    Glad to hear its almost back on the road Joe!!
  18. 1958apache
    1958apache
    Sorry to hear about the truck... I think I have decided on the L78's... Now I can't decide on 3" or 4".... Do you think the 4" wide whites will be too wide white? Is that possible?
    BTW... Like the Chucks... I got a set of PF Flyers myself. :cool:
  19. Poltax
    Poltax
    from UT
    Just saw this thread. Great truck.
  20. SanDiegoJoe
    SanDiegoJoe
    Yeah man, I can't wait!
    I thought that the 4" were too wide. Too gangster.
    thanks Poltax.
  21. 1958apache
    1958apache
    Joe,
    It looks like you are running the stock wheels. I ***ume you don't have any issues rubbing on the steering arm? I was looking last night and thought it might be a little close. Any feedback on clearance?
    Thanks!
  22. SanDiegoJoe
    SanDiegoJoe
    The steering arm rubbed worse on radials.
    Only at full clock to they rub.
    - Joe
  23. WTFHemi
    WTFHemi
    from Austin
    Yep, thats how they got my bias plys on the radir wheels
  24. SanDiegoJoe
    SanDiegoJoe
    It's getting close!
  25. 1958apache
    1958apache
    Joe,
    Thanks for the tire recommendation. I went with the 4" L78's. It does rub a bit at full lock to the right, I'll make a limiter for it, but I'm loving the look. I still need to get a dropped axle too!
    I just got the wheels back from the powdercoater and everything mounted up. I still need to find a bullet cap to fit the stock wheels.
