Projects 1959 Chevy pickup build
Discussion in 'The Hokey Ass Message Board' started by kylemontoya, Oct 28, 2012.
  1. kylemontoya
    kylemontoya
    I bolted a chain from the crossmember to the rear end. It didn't seem right allowing the bags to stretch out so much if I had the truck on a lift or something. Anyone else do this? Was it necessary? ImageUploadedByH.A.M.B.1405747346.161806.jpg ImageUploadedByH.A.M.B.1405747359.918089.jpg
    Wrapped it in electrical shrink wrap so it won't make noise.
    Instagram @kylemontoya
  2. 61dailyf100
    61dailyf100
    Just wondering , how much heat can that pasti dip paint take ? Interesting way if dressing the engine. Let me know how it takes the heat I kinda wanna try it.
  3. kylemontoya
    kylemontoya
    It says on the can 200°, but my friend put it on his harley engine case, and that thing gets pretty hot. Also I saw some Hondas that did it to the valve covers. I'll let you know how it holds up soon!
  4. ElBrujo
    ElBrujo
    That's my concern as well, I figure that can't be good for the bags.
  5. Hotwhilz
    Hotwhilz
    from France
    You are bustin' ***! As far as bags limiting travel, I usually use the stroke of the shocks to limit the stroke ;)
    Works like a charm
  6. kylemontoya
    kylemontoya
    My dad had some long travel dune buggy shocks that he gave me, so 14" of travel was too much haha. But I think now that the system holds air Maybe I won't need the chain... Thanks man!
  7. kylemontoya
    kylemontoya
    So the brakes are plumbed, electrical is done except for the tail lights, I ordered a driveshaft yesterday, I'm waiting for a buddy to bring me stainless steel line for fuel, and I'm waiting on a few fittings for the ****** cooler. I'm going to drive this thing around the block soon! I still need a drivers side door haha, but it'll drive without it right?
  8. kylemontoya
    kylemontoya
  9. kylemontoya
    kylemontoya
    Taken before driveshaft and fuel tank were in
  10. jeffrob
    jeffrob
    looking good ! cool truck
  11. RamJet1
    RamJet1
    Very nice build, well done.
    Question on the gas pedal. I have that same one, but had trouble mounting it so that I still got Wide Open Throttle. Did you modify the linkage that sticks out the bottom to get WOT? Thanks, and looking forward to the video of you cruising around the block sans driver door.
  12. bobss396
    bobss396
    The chains are a great idea. I used them on my stock cars with rear coils since the springs were so short, they could fall out when I had it jacked up.
  13. kylemontoya
    kylemontoya
    The throttle was a pain, I'll try and take some pictures, but there's a hole for the linkage for when you press the throttle, then as it comes up it goes back into the cab. Sort of angled back. I have two holes drilled, one for the throttle cable housing, and one smaller for the cable.
    Thanks guys I'm excited!
  14. kylemontoya
    kylemontoya
  15. RamJet1
    RamJet1
    I see now, thanks for the picture. I may need to make a nice bracket like that. Did mine years ago, but the project has been sitting, waiting, for years. Seeing yours is inspiring.
    Thanks.
  16. kylemontoya
    kylemontoya
    First drive! Sorry for the low quality video
  17. RamJet1
    RamJet1
    Love the seat! Congrats on getting to drive it.
  18. kylemontoya
    kylemontoya
    ImageUploadedByH.A.M.B.1406788557.419493.jpg ImageUploadedByH.A.M.B.1406788572.683198.jpg ImageUploadedByH.A.M.B.1406788586.777422.jpg
    Got the carpet behind the seat done. Molded carpet is in the mail
  19. kylemontoya
    kylemontoya
    Pretty bummed, this 700r4 isn't shifting into 3rd. I traded a th400 for it on cl and I don't think the guy was being honest... Anyone have advice?
  20. kylemontoya
    kylemontoya
  21. Hotwhilz
    Hotwhilz
    from France
  22. kylemontoya
    kylemontoya
    Thanks!
    I replaced the bad 700r4 on Monday, I regrettably purchased a cheap eBay kick down cable, I ordered a lokar earlier. I also had to replace the cheap throttle I bought for a lokar. Lesson learned!
  23. kylemontoya
    kylemontoya
    My truck is driving pretty good, needs the alignment done but I cruised up to 90 today and around town with no problems. Then I came home and the radiator fans were running, I didn't think much at the time but they usually turn off with the ignition off. A few hours later I had a dead battery. Also my thermo was giving me abnormal reads, maybe the switch is bad?
  24. kylemontoya
    kylemontoya
  25. ElBrujo
    ElBrujo
    Really nice! What size valves are you running?
  26. kylemontoya
    kylemontoya
    Plasti dip is holding up great! Thanks for asking.
    Elbrujo, I don't know the valve size... It's a 283 with LS high compression pistons and oversized cam
  27. kylemontoya
    kylemontoya
    A bolt on the flexplate came loose and i damaged a few teeth... Pretty annoying, but I'll replace it and the starter next.
  28. 61dailyf100
    61dailyf100
    Sweet ! Gotta go get me a can of that stuff then. Nice build by the way I really like those trucks.
  29. ElBrujo
    ElBrujo
    I meant the valves for the airbags.
  30. kylemontoya
    kylemontoya
    Oh haha I don't know that either :/
