Projects 1959 edsel ranger build
Discussion in 'The Hokey Ass Message Board' started by Hotrodmnm, Mar 30, 2017.
  1. charleyw
    charleyw
    Good Luck with your project.
    Here's Dad's, bought new in '59. 13 year old me bought spinners and screwed them to the stock hubcaps.
    4 door hardtop Ranger if I remember correctly.
    guthriesmith likes this.
  2. philo426
    philo426
    Did you replace the floor?Looks rock solid!
    unclescooby likes this.
  3. bobss396
    bobss396
    Headliner bows, they have an order to them. From the factory they have a color-code on them which may be gone since its a dot of paint, so if they come out, tag them. I've been told that the back gl*** has to come out for the headliner to be tucked in, I'd ask around when you get to that. The window gasket is available, same as the '59 Ford.
  4. Hotrodmnm
    Hotrodmnm
    from payson
    I didn't replace the floor. Just cleaned it super good. I do still have one spot to patch on the drivers side. But it was pretty solid before, just extremely dirty. It's funny what a wire brush can do.
    ~Hotrodmnm
  5. bedwards
    bedwards
    Are you kidding? Someone did a bad job on my headliner and was thinking about redoing it. Not now.
  6. dave 62 pb
    dave 62 pb
    Doing a good job keep it up , good advice on the chrome and gl*** the previous owner of mne was careless with the grinder my windsheald has tiny bubbles in the laminate where hot sparks have hit, doesnt affect the vision but its annoying and could have been prevented
    Here is mine as it is at the moment
    loudbang, bobss396 and bedwards like this.
  7. bobss396
    bobss396
    Maybe the back gl*** does have to come out to do it right. I would ask at an upholstery shop first. This is what my gl*** guy shared with me.
  8. bobss396
    bobss396
    I cleaned my floor pretty well. It had primer on it but had the old rubber mat and that jute backing stuck to it. Got it cleaned, primed a few spots and shot a quart of white lacquer over it, Duplicolor from Auto Zone. I found a patched piece about 5" x 7" by the gas pedal, it was fibergl***ed over but looked solid. The panel under the back seat is thin plywood cut to fit.
  9. Hotrodmnm
    Hotrodmnm
    from payson
    So today, I got the back fender halfway done. Before I ran out of sanding disks. [​IMG]
    Also I we took these wheels off an old jaguar we have, I think I'm going to put these on my car. They are old wires. What do you guys think?[​IMG][​IMG]
    ~Hotrodmnm
    Chavezk21 and loudbang like this.
  10. Lebowski
    Lebowski
    I like the original look better, to be perfectly honest with you. I have a nice set of Edsel wheel covers available in case you're interested....
  11. squirrel
    I think the Jag wheels are Chevy bolt pattern (5 x 4.75") not Ford, but I could be wrong.
    I also don't like wire wheels, but it's not my car, it's your car.
  12. bedwards
    bedwards
    I guess its where your going with your car. What look are you after. I like spokes on the Edsel. I've seen one somewhere and if I find it will get you pics. I like the originals also and that's how I went with mine. The originals with the spinners looked the best but are hard to find. The spinners were gone off of mine so I made the spinners.
    before:
    [​IMG] [​IMG]
    after:
    Peanut 1959 and loudbang like this.
  13. xpletiv
    xpletiv
    from chiburbs
    Post up a shot of your car or find one like it on the "Photoshop" thread. This way you can check out different options for wheels.
    loudbang and Hotrodmnm like this.
  14. Hotrodmnm
    Hotrodmnm
    from payson
    Yes they are. But they're old enough that they had the "multi pattern" so they were built to fit multiple patterns. They fit ford as well.
    ~Hotrodmnm
  15. manyolcars
    manyolcars
    koolkemp, loudbang and bobss396 like this.
  16. philo426
    philo426
    Pretty cool putting 59 Caddy taillights in the center of the originals!
  17. Hotrodmnm
    Hotrodmnm
    from payson
    Got the trunk painted today! Hoping to get the wheels on it soon!
    ~Hotrodmnm
  18. koolkemp
    koolkemp
    Use a box cutter or similar blade and s****e the gl***, this will remove most of the metal bits, and prevent rust appearing on the gl***, it works pretty good , Gene Winfield told me this , it will make some difference.
  19. Baldies
    Baldies
    You are going to have a great ride. A razor blade will take off a lot of paint with no damage to anything else. No scuff marks on the metal etc.
  20. Hotrodmnm, when you are using the "scotchbrite" wheels, do not using any pressure as it will wear out the material very fast. I noticed the deep swirl marks in the metal. I did my 47 Ford p/u body and doors that had at least 5 coats of paint using only one wheel.
  21. a4t1rat
    a4t1rat
    from Utah
    So she is back at it, went and bought more sanding pads and another grinder, she had a small delay ... had to clean her room [emoji23]. So here is a pic of her hard at work taking off the door chrome. 20170415_202617.jpg
    Sent from my SM-G935V using The H.A.M.B. mobile app
    loudbang and bedwards like this.
  22. Hotrodmnm
    Hotrodmnm
    from payson
    Finished almost half the car! Going to get primer soon!
    ~Hotrodmnm
    koolkemp, Flogknaw and loudbang like this.
  23. Hotrodmnm
    Hotrodmnm
    from payson
    So a special thanks to a friend by the username "ottoparts" for the hubcaps! [​IMG][​IMG]
    ~Hotrodmnm
  24. Hotrodmnm
    Hotrodmnm
    from payson
    Got almost everything that was sanded primed today as well. Looks better, now I can see all the dents. And everything else that needs work[​IMG][​IMG]
    ~Hotrodmnm
    Squablow, Flogknaw and loudbang like this.
  25. Hotrodmnm
    Hotrodmnm
    from payson
    Iso: original edsel radio. If anyone has one that they'd be willing to sell or knows of someone, please let me know! Thanks
    ~Hotrodmnm
  26. upspirate
    upspirate
    You can always run both the wires and the stockers for a different look....just takes 20 nuts to change the look!
    (I like wires!!:))
    Glad to see a young woman getting into this hobby AND doing the work
  27. dave 62 pb
    dave 62 pb
    Making good progress there, what are your plans for the paint , keep the photos rolling in
    Mines up and driving now I love every minuet that i drive it
  28. Hotrodmnm
    Hotrodmnm
    from payson
    I'm not sure on paint. I originally wanted to do it turquoise and white. But as I have looked further in to it, I have been considering red and white, and black and white. I love the way your car looks!
    ~Hotrodmnm
  29. Hotrodmnm
    Hotrodmnm
    from payson
    [​IMG][​IMG]
    I have officially finished over half of my car! The bent grill is out, getting ready to put the chrome back on!
    ~Hotrodmnm
  30. loudbang
    If you are thinking of painting it any time soon leave the chrome off and put it back on after painting it. That makes for less time taping it all and easier sanding because you don't have to worry about accidentally sanding the chrome. :)
