1959 f100 build
Discussion in 'The Hokey Ass Message Board' started by 510madmav, May 13, 2010.
  1. 510madmav
    510madmav
    Thank you, not running one at the moment.
  2. 510madmav
    510madmav
    Header. Made by patriot. Ran dual 1 & 3/4 To 25in. Gl***packs. Sounds good.
  3. Bone Head
    Bone Head
    from Kansas
    Nice, thing's look as if they are coming together. I dig 57-60 Ford truck's.
  4. 510madmav
    510madmav
    Thanks. Still have the collapsing lower rad hose issue! I put two jugs of vinegar and the rest water in my cooling system because the rad rows in the core are full of rust deposits/ chunks/ flakes. Radiator is probably getting pretty clogged . Anyone know how long I can leave the vinegar in there before it starts to damage things ? Main concern was head gasket.
  5. 56 ford custom
    56 ford custom
    from Socal
    The truck is coming along real well. Lookin good.
  6. damagedduck
    damagedduck
    from Greeley Co
    good looking build.
  7. dixiedog
    dixiedog
    Great work - for the vinegar, I would say a day but that is a uneducated guess.
    really like the front bumper nice lines
  8. Cymro
    Cymro
    Have you reverse flushed the radiator, by simply removing it once the vinegar solution is dispensed with and running a water hose into the bottom of the rad, (prop the rad upside down) this is the opposite direction to the normal flow and will usually clean out all sorts of loose debris, you may also like to neutralise the vinegar with a solution of baking soda and water, prior to rinsing through with a hose.
  9. Nice work, your truck is going to come out great!
  10. 510madmav
    510madmav
    Well I left it in for appx 24 hrs.. Flushed it out, only a little brown. Used baking soda to neutralize. I'm getting the rad rebuilt because the core tubes are plugged bad with rust nuggets . I think that is the reason for the collapsed bottom hose.
  11. 510madmav
    510madmav
    Drove today on the highway for the first time w the new rad. Was running a cool 160, coming home I can watch the needle rise,170,200,210 in minutes. After 500 somethin dollars later for a radiator rebuild, & 3 row core, I'm back at square one. Rust nuggets in all the rows. I'm pissed . The deposists must have released after really warming up on the highway, because around town it ran at 130 .Does anyone know how to really clean this rust out?
  12. 510madmav
    510madmav
    I filled it up again w vinegar tonight, I will leave it in longer this time. I'm thinking I will have to pay a bunch more to have the rows cleared again, so I came up with an idea; a portion of both top and lower hoses will carry a fine mesh screen . You oughta see the chunks that come out of the rows with my magnet stick. I have no other options.
  13. 510madmav
    510madmav
    Or even netting, something strong that won't tear, I'll wrap it around the inlet and outlet on the rad. Then slide the hoses on over.
  14. Fedman
    Fedman
    I have heard of using nylons as strainers for this. :eek:
  15. 510madmav
    510madmav
    Well, that's the right idea.
  16. Google Gano filters
  17. stukks
    stukks
    I knew a guy with a 223 in did 1956 f100. He chased an overheating problem for a for a year or two. He tried multiple radiators aluminum and br***. Only after installing a more modern engine did he realize that his temp gauge was not working correctly. I might start there.
  18. salf100
    salf100
    What's an edsel air cleaner look like??
  19. After repairing the roof [great save by the way] a little thing like overheating can`t stop you!
  20. Flathead Johnny
    Flathead Johnny
    from MA
    great work...i look forward to more
  21. Hotrod1959
    Hotrod1959
  22. 53olds
    53olds
  23. 510madmav
    510madmav
    Thanks for the interest. Not much update, I have a drop axle and plan on flipping the rear pretty soon . Other than that , just been driving the hell out of it daily.
  24. johnboy13
    johnboy13
    I know I'm a little late on the overheating issue, if you haven't gotten all the rust cleared out the nylon trick does work. Cut the foot out of one nylon and slick it in the upper hose at the thermostat housing, fold the end over so that the clamp will hold it on. Drive it and make sure to clean it out frequently, like after every drive. Eventually you'll get all of the **** out.
  25. Rob68
    Rob68
    The truck is lookin great man. I have used Gano filters in some of my cars and the work great (if you are still having that problem). Good luck with the truck!
  26. 53olds
    53olds
    Awesome!
  27. frankenstein1948
    frankenstein1948
    Nice save!
    I've owned many of these over the years and never seen one with rot in the roof like that.
  28. JDiGio1960
    JDiGio1960
    from Ventura,CA
    really curious as too what those metal brackets are? and too where did you find them? im starting roof rot soon on my 60' and need help!
  29. frankenstein1948
    frankenstein1948
    You can buy them at harbor freight in the welding section or any welding supply store.
  30. 510madmav
    510madmav
    yep, called **** welding clamps. easy to make, theyre over priced for what they are
