Hot Rods 1960 Apache Crew Cab Build
Discussion in 'The Hokey Ass Message Board' started by Vintage Vandal, Jun 8, 2021.
  1. Vintage Vandal
    Vintage Vandal
    here’s the link to the Amazon shifter. Look at the first pic of the shifter in this thread and you can see where I cut it. I had to drill out holes bigger to make it work. Then cut the steel post and weld it at 90 degrees more or less.
    MAGQOO Racing Short Throw Quick Shifter Compatible with 83-04 Ford Mustang 83-88 Thunderbird T5 T45 /85-90 Cosworth T5 Black https://a.co/d/3F**dir
  2. 57tailgater
    57tailgater
    from Georgia
    Thanks and good solution. I got mine off that auction site but they all look to be the same for basically the same application. I have a longer Indy stick I that I will drill mounting holes in to use on mine. It's really funny one cannot find the difference between the shifter mounting bolt pattern. Do you still have the original shifter?
  3. bobss396
    bobss396
    Welds come in all shapes and sizes... have at it.. :cool:
  4. Vintage Vandal
    Vintage Vandal
    nope. I never had an original shifter. I would’ve been glad to cut up the original
  5. Vintage Vandal
    Vintage Vandal
    IMG_1618.jpeg Got the rear crossmember welded in. Next I’ll need gussets for the rear spring brackets
  6. Vintage Vandal
    Vintage Vandal
    IMG_1636.jpeg Cut off the old shock mounts from the original frame, and put the old crusty coil overs for the time being
    catdad49 likes this.
  7. Vintage Vandal
    Vintage Vandal
    Driveline is back from the shop. Brakeline is extended and more fish plates welded in IMG_1642.jpeg
  8. Vintage Vandal
    Vintage Vandal
    Used some 1”x2” tube for the metal IMG_1649.jpeg IMG_1648.jpeg bed strips to bolt to.
    catdad49 and 41 GMC K-18 like this.
  9. BJR
    BJR
    I don't think those shocks will do much due to the angle they are at. Almost look like they could go over center under compression.
    WiredSpider and Day 2 like this.
  10. Mike Lawless
    Mike Lawless
    Nice fab work on the frame extension. Maybe even overbuilt. But overbuilt is good for ch***is stuff.
    I have to agree with BJR on the shock angle. My F100 has the stock shocks mounted at a pretty severe angle too, but not nearly as severe as yours. I elected to put air shocks on the rear for those occasions when I would put some weight on the back. However, they are fairly ineffective. Putting 75PSI in 'em doesn't even raise the *** end an inch.
    However, over time, using the truck, you'll be able to figure out what works and what doesn't. You look to be the kind of feller that wouldn't be afraid to cut it off and start over if it don't work.
    So....Carry on!
    41 GMC K-18 and bobss396 like this.
  11. Vintage Vandal
    Vintage Vandal
    IMG_1670.jpeg IMG_1669.jpeg Finally got to take the limo on an 11pm first test drive. No drive line vibrations that I can tell. And the truck rides way nicer. Not sure if it’s the leaf springs instead of the coils, or the longer wheelbase, or both. But it’s a night and day difference on ride quality. Still have some wiring, ebrake, and of course the camper shell to ****on up, but it was nice to have it mobile again
  12. guthriesmith
    guthriesmith
    Looks great! Proportions are so much better with the long bed with that cab in my opinion! :cool:
  13. That’s pretty typical shock angel on a truck.
    guthriesmith likes this.
  14. BJR
    BJR
    Must be the camera angle then, the angle looks much steeper in your photo.
  15. brEad
    brEad
    Looks great with that long bed on it! Nice job!
    Budget36 likes this.
  16. Yes sir home run, the sum is worth much more than the individual parts. Not sold on the cap yet, that might cause some serious blind spots.
    Budget36 and Vintage Vandal like this.
  17. Jim Bouchard
    Jim Bouchard
    That thing looks *****EN!!!!
    Vintage Vandal likes this.
  18. bobss396
    bobss396
    Nice look, I wasn't sure at first but it fits the rig well. What is the turning radius like?
    SS327 and Budget36 like this.
  19. Vintage Vandal
    Vintage Vandal
    Not sure yet. I haven’t put many miles on her yet. But in a couple weeks I’m taking the truck to the Hot August Nights show in Reno NV. And I’ll have to park in a parking garage. I’m not exactly looking forward to that
    SS327, catdad49, Budget36 and 4 others like this.
  20. 41 GMC K-18
    41 GMC K-18
    I really like how your project is making progress !
    Style and comfort and patina, and the ability to carry a load!
    brEad likes this.
  21. 51504bat
    51504bat
    From when I had my OT Ford long bed crew cab, when parking in a structure drive to the roof. Much easier parking. IMO
    41 GMC K-18 likes this.
  22. bobss396
    bobss396
    My Ford is manual steering, I pick where I park carefully.
    51504bat likes this.
  23. Budget36
    Budget36
    Please tell us you will someone along with you that can take a video of “the park” ;)
    I agree with all, proportions are so much better, but dang she’s long!
  24. I once heard it takes a long board for a good teeter.
  25. Vintage Vandal
    Vintage Vandal
    IMG_1687.jpeg IMG_1686.jpeg IMG_1685.jpeg I got a lead on an overdrive setup for my sm465 . Does anyone know what this setup is? I know nothing about it.
  26. 4 pedals
    4 pedals
    from Nor Cal
    Those overdrive units were made by Gear Vendors at one time, now somebody else sells them. From the research I've done, they are reported to have been originally designed in the WWII era, and can be quite noisy I'm told. As you can see, they go between the bellhousing and the transmission, and require that nice new driveshaft you just had made to be shortened. I've thought about getting one for my parts chaser truck with the granny 4 speed, not so much for the overdrive, but to split gears since the spread on the ratios is so wide.
    Devin
    catdad49 and Vintage Vandal like this.
  27. Vintage Vandal
    Vintage Vandal
    Put a few hundred miles on the rig going to Reno for Hot august nights. Had to battle some parking garages and some parallel parking situations with manual steering. That’s going to change real soon. I ordered the power steering kit from captain fab. When it’s time for a 427 motor swap, it’ll go on. IMG_1777.jpeg IMG_1774.jpeg
    catdad49, brEad, SS327 and 3 others like this.
  28. Vintage Vandal
    Vintage Vandal
    Been making some progress. I ordered a power steering adapter kit from Captain Fab. It went together well with no issues. Also put in a mildly built 427. Had to cut and recess the firewall for the valve covers and weld in a tube motor mount in place of the old horseshoe mount. and now the truck has tons of power ( at least compared to the tires 305. However it’s running hot now. Next step, figure out how to put in a much larger radiator and better fan set up. I have no room for a mechanical fan which I usually prefer IMG_1915.jpeg
  29. catdad49
    catdad49
    What a Beast, especially like it with the camper shell. A/C, power steering, what's Next?!
  30. bobss396
    bobss396
    I have had one of those Trans Dapt mounts on the shelf for well over 40 years...
