Projects 1960 caddy engine,worth picking up?
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, May 6, 2020.
  1. rustydusty
    rustydusty
    Instead of yanking a running engine out of the coe, you should build a car around the Caddy engine!
  2. iwanaflattie
    iwanaflattie
    I have a 1955 vanette that could use a torque monster ..
    A 37 GMC with a 270 Jimmy
    A 50 GMC homemade coe that I'm putting a 292 inline....
    I got enough projects
  3. Ya never know what will happen. Always good to have a motor in the wings.
  4. speedbump
    speedbump
    it maybe a good deal if you can use it. don't forget the early gm mtrs. don't except late model trans. without adapter plate. good luck
  5. Well that's hot rodding I guess. I remember finding an adapter or two to bolt a small block up to an early Ford transmission when I was younger. Some things just never change. :D
  6. iwanaflattie
    iwanaflattie
    Thanks guys.
    I got curious and popped the valve cover off.
    I drained the oil and it was black but no water and it spins freely..
    Might be a runner..
    I'm picking an 2x2 Edmunds with a couple of zeniths on top...and maybe a couple of finned valve covers..
    clunker and warbird1 like this.
  7. Roothawg
    Roothawg
  8. clunker
    clunker
    from Boston MA
  9. iwanaflattie
    iwanaflattie
    Btw it's a 61.
    61J070133
  10. iwanaflattie
    iwanaflattie
    Is the 380/Hydra-matic transmission a good candidate for a swap or do people prefer the manual conversion for certain "hot rod feel"
    31hotrodguy likes this.
  11. Roothawg
    Roothawg
    I bought a bellhousing for a 5/6 speed. The Early Caddy cranks were drilled for sticks, but the later engines were automatic only. Look at the Wilcap adapters for options.
  12. clunker
    clunker
    from Boston MA
    (You mean 390? Caddy 390?) Depends on your budget. Depends on the project. (Going in a Caddy? An A? )Most likely, a used engine will come with a hydramatic 4 speed, or you can find one pretty easily for cheap. I found a complete one on ebay for $300, bought it for parts. (Some hard to find **** in there). I rebuilt my stock Hydramatic myself for around $350, starting with little or no skills (Fatsco Transmission kit). Very doable. Performs awesome; Chug along in high gear on the freeway basically at idle. I love it. I am always drinking coffee or eating doughnuts with one hand, so I like an automatic, sit back burn up some highway. Text. Find a better song on the radio. Take my jacket off while driving. Discipline children in the back. Life’s good.
    If I were loaded (with money), would I buy an adapter, put a manual transmission, custom built driveshaft, starter, fabricate linkages, speedo connection, etc? Yes. You wouldn’t believe the trouble I would get myself into if I had the bread.
  13. iwanaflattie
    iwanaflattie
    Great news...thanks...I meant 390....sorry for the typo
  14. 49ratfink
    49ratfink
    $200 is way cheap. I parted out a Y block and a 216 Chevy 6 and got more than that for the lighter shipable bolt on parts for each.
