Projects 1960 f100 short bed custom cab w/big window
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, May 23, 2011.
  1. 56 ford custom
    56 ford custom
    from Socal
    I really dont plan on having children in this truck.
  2. johnboy13
    johnboy13
    I guess it's your call then. I lost a wheel cylinder on the rear of my truck, with a dual chamber master cylinder, and was not only able to stop, but I was still able to get home as well, I don't think I could have said the same on either account with a single chamber master.
  3. 56 ford custom
    56 ford custom
    from Socal
    Where can I get a decent priced and quality kit for that then?
  4. Jaybird60
    Jaybird60
    I've been looking into the same set up as well, I've seen them on ebay and CPP has a whole kit as well. Anywhere from $180-250, but well worth it. By having the dual MC it basically divides the front and rear brake system, so if something fails on either end, you still have braking on one end or the other, if you follow me.
  5. 56 ford custom
    56 ford custom
    from Socal
    Ok cool. I want something complete and direct bolt on so ots easy and quick.
  6. johnboy13
    johnboy13
  7. 66Newport
    66Newport
    Glad you are ok! It could have been a lot worse.:eek:
  8. johnboy13
    johnboy13
  9. 56 ford custom
    56 ford custom
    from Socal
    Thank you 66, you are right....could have been much worse.
  10. 56 ford custom
    56 ford custom
    from Socal
  11. 56 ford custom
    56 ford custom
    from Socal
    I have purchased all new motor and trans mounts. Its been a while so can some f100 guys help refresh my memory on how these go back on?
  12. 56 ford custom
    56 ford custom
    from Socal
    For the morning crew
  13. 56 ford custom
    56 ford custom
    from Socal
  14. 56 ford custom
    56 ford custom
    from Socal
    Where are all the fridge guys at? Also having issues with the dizzy.
  15. 56 ford custom
    56 ford custom
    from Socal
    Nobody knows about these mounts?
  16. MrHavard
    MrHavard
    I think someone posted photos of these mounts on the facebook group yesterday. If I had a scanner Id scan my service manual.
  17. 56 ford custom
    56 ford custom
    from Socal
    Harvard, I got it. Thanks
  18. 56 ford custom
    56 ford custom
    from Socal
  19. 56 ford custom
    56 ford custom
    from Socal
    In the process
    Finally in
  20. 56 ford custom
    56 ford custom
    from Socal
    Now I have to buy a trans cooler since I took everyones advice on not using the original trans cooler mounted on the trans. Looking to see what brand,model and where to buy it
  21. 56 ford custom
    56 ford custom
    from Socal
    Can you post a pic or a url from a parts store so I know which one to get?
  22. 56 ford custom
    56 ford custom
    from Socal
    Still in need of a p***enger front leaf spring pack in Socal. No luck yet.
  23. chaddilac
    chaddilac
    Which spring you need? Spring can make them pretty cheap!!
  24. 56 ford custom
    56 ford custom
    from Socal
    Chad I need the top one right under the little square one
  25. 56 ford custom
    56 ford custom
    from Socal
    Well still no luck finding a spring pack near by. Should I just by some drop springs? Or just keep searching for a stock set? Should I buy both sides? I was just thinking if they come off of two different trucks they might be worn differently?
  26. chaddilac
    chaddilac
    Take the old one to a spring shop, have them make two like it. Unless you want to lower the truck at some point and buy lowered springs, then put the money towards them.
  27. 53olds
    53olds
    Thats progress I like to see buddy!
  28. 56 ford custom
    56 ford custom
    from Socal
    I was contemplating having new springs made but I dont see a point to that. I was hoping to score a pair of used stocks somewhere local but that fell through. Im thinking dropped springs but dont know what brand or how much to drop. Saw a pair of mono leafs in the cl***ifieds but heard it rides like ****.
  29. 56 ford custom
    56 ford custom
    from Socal
    About time...right?? Haha. It took forever but finally going. Been going through alot with everything. Super stressed.
