Projects 1960 f100 short bed custom cab w/big window
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, May 23, 2011.
  1. 56, I went out and looked at my parts and I can't tell looking at them since the engine is apart. It sort of looks like the mount might come off with out pulling the balancer, but I am not certain.
    The engine mount for the truck has a slot that the crank snout sits in and is held in with four timing covers bolts on the one I have. That being said, I have no idea about the engine mount that is on the engine in the pic.
    Jeff
  2. 56 ford custom
    56 ford custom
    from Socal
    fauj, Thanks. I need to figure this out asap. I need to get this motor together and into my truck.
  3. I would just take the bolts out and see if I could wiggle the mount out. No harm in trying.
    Jeff
  4. 56 ford custom
    56 ford custom
    from Socal
    I will have to atleast try that then. But if I want to run the power steering on my 56 sedan I will have to get the balancer off that motor and swap it off with the one off the old motor. Is there only one right way of installing it?
  5. It is keyed so that it will only go on the one way. Just be sure not to use a hammer to remove or install the balancer. Use a puller to remove it and you can use the balancer bolt to install, just be sure that it is oriented correctly on the crank before you start wrenching it on so that you don't damage the crank or the balancer.
    Jeff
  6. 56 ford custom
    56 ford custom
    from Socal
    Thanks a bunch fauj, I will listen to your directions because I cant afford to damage this motor.
  7. 56 ford custom
    56 ford custom
    from Socal
    Well I did the "tail light resto" and also painted my hood hinges gloss black. They came out.nice.
  8. I look forward to see the pics. I haven't done anything with mine lately... Just trying to get a transmission so that I can mock it up and build brackets for everything.
  9. 56 ford custom
    56 ford custom
    from Socal
    I will pist pics as soon as I can. What trans are you going to be using?
  10. I have been looking for a small block ford ZF5 two wheel drive trans... found a few, people out here seem to think that they were cast in gold. :eek::D
  11. 56 ford custom
    56 ford custom
    from Socal
    Yeah I hear ya haha. Im just running the good ol ford o matic
  12. 56 ford custom
    56 ford custom
    from Socal
    Well I went to go shoot another coat of white inside the tail lights but this last coat for some reason reacted? Some of the paint is bubbling or peeling up. What went wrong?
  13. Gemini's journal
    Gemini's journal
    hey their my name is tony and i am the proud owner of a 59 big back window f-100. i like were your going with your build. i just joined the hamb and your the first person i talked to. we have a little in common because our trucks body style is the same except the grill. the right wheel and tire combo with a low stance sets these trucks apart from the rest. good luck with your ride. hopeing to upload pics of my truck soon.
  14. 56 ford custom
    56 ford custom
    from Socal
    Hey tony, welcome to thehamb. This is a great place to find and learn pretty much anything you need for your hot rod or custom. There is a 57-60 f100 group here that you should join.
  15. Gemini's journal
    Gemini's journal
    im new member of the hamb i got a 59 f-100 unique looking indeed mine is big back window custom cab. hopeing to get pics on my profile your truck looks good is it original paint.
  16. Gemini's journal
    Gemini's journal
    sounds like a good idea
  17. Gemini's journal
    Gemini's journal
    how do you join groups on the hamb
    :D
  18. 56 ford custom
    56 ford custom
    from Socal
    Go to the search bar and typr in the group then when it pops up on the top of the page should have a join ****on iif I can remember right
  19. 56 ford custom
    56 ford custom
    from Socal
    Well I finished painting the hood hinges today. They came out nice and shiney. I used rustoleum on the hinges and I hope it stand up and lasts. I used krylon gloss white for the inside of the tail lights I hope it withstands the heat of the bulb and doesnt flake.
  20. MrHavard
    MrHavard
    Did you buy new sockets for your tail lights? I need to do this as well.
  21. 56 ford custom
    56 ford custom
    from Socal
    No I havent bought new ones yet, Im contemplating on rewirring the whole truck. I dont know where I can but the sockets with the pig tails and rubber boot that goes around the end of the tail light housing.
    Preimered before paint
    Gloss black
    Gloss white inside. I used krylon indoor outdoor. I hope it withstands the heat of the bulb.
    Here are my hood hinges that I painted gloss black with rustoleum.
  22. Big Nick
    Big Nick
    Here is the link to their site and some people said their local NAPA stroes carried it.
    http://www.kbs-coatings.com/
    Thanks for the compliment on the bike!!
  23. 56 ford custom
    56 ford custom
    from Socal
    So the new y block I got i am pretty sure its out of a 56 f100, im not sure If I want to run this car and manifold or the one of my old motor.
    This is the old one with the weird chole on the side. The hose that is on the choke got to the base of the intake. Then the vac*** advance goes to the base of the carb.
    Or should I use the Rebuilt holley and painted intake from my old 292?
    This carb has a manual pull choke
  24. 56 ford custom
    56 ford custom
    from Socal
    I will be pulling the motor and.trans soon so I can paint the frame and firewall. What type of paint should I use on the firewall? Also what should I use to clean it?
  25. 56 ford custom
    56 ford custom
    from Socal
    Any y block or 57-60 f100 guyd want to chime in on this?
  26. Kage
    Kage
    from Delano, TN
    If you want to keep it low buck and use something that is durable, go to Tractor Supply Co. You can pick up some tractor enamle for a good price. 30 bucks for a gallon..and about 10 for a pint. The stuff works great and they have several colors to choose from.
  27. 56 ford custom
    56 ford custom
    from Socal
    Kage, there isnt one near me.
  28. Big Nick
    Big Nick
    in my eyes, paint is all about prep. Get your hands on a good degreaser, scuf it up and spray. You can probably get away with Duplicolor or Rustoleum if you want to stay on the cheaper side. Just make sure its clean!
  29. 56 ford custom
    56 ford custom
    from Socal
    I just want the fire wall nice and clean. What have you guys used? Pics?
  30. Gemini's journal
    Gemini's journal
    hey i followed your dirrections your truck seems to be comeing along cant wate to see the final product. send me some messages when you get this message thancks.
