1960 olds missing intake parts!
Discussion in 'The Hokey Ass Message Board' started by Dyna88Kid, Aug 11, 2013.
  1. Dyna88Kid
    Dyna88Kid
    I'm only 17, and I just started getting into the mechanic/reso-mod thing, so give me a break if I say something stupid.
    Anyways, my olds is missing some part and I don't know what it even is. I can't find any pictures of 60 olds engines that aren't a) too blurry b) incomplete engine or c) have giant air cleaner on so there's nothing to see but filter.
    This part sits on top of the manifold forward of the carb and behind the thermostat housing. There are two ports that water circulates through when the engine turns, and two very thin bolt holes that sit further back. Something has to go there, but I can't imagine what. Pictures available if needed.
    Any help would be greatly appreciated!
  2. Dyna88Kid
    Dyna88Kid
    Those pictures I mentioned:
  3. Dyna88Kid
    Dyna88Kid
    Well... That didn't work well. That's not my engine, one like it.
    Mine is here:
  4. 2racer
    2racer
  5. Dyna88Kid
    Dyna88Kid
    I actually am on that site, however the admin is never on and he's been doing maintenance on it for like a year. Nobody ever replies when I post there.
    GO OLDS '60!!!
    the most comfortable ride you ever tried!
  6. GOATROPER02
    GOATROPER02
    from OHIO
    Those are just intake bolt holes.....put 3/8 -16 thread bolts with sealer on them.....all early Olds intake bolt holes are drilled into water and will leak if not sealed......same with the bottom row of ex bolts
  7. Deuces
    Deuces
    Looks like your also missing the fuel line that goes from the fuel pump to the front of the carburator...;)
  8. 2racer
    2racer
    these might help
    looks like power steering bracket
  9. chopolds
    chopolds
    from howell, nj
    Not power steering...this is a 61 intake, that has PS, doesn't have the bungs like on yours. I don't have them on my 55, either. Might be from a truck or similar? Maybe for a governor mount?
  10. Paul
    Paul
    Editor
    not a stupid question at all, smart in fact.
    if you are talking about the two holes on the number 3 intake runner in the picture of your engine those are for the dashpot, it keeps the throttle from returning too fast when you let off suddenly.
    here's a picture of an intake I pulled from a '60 394 a while back
    hard to see in this picture but the inboard hold down bolt is hollow for the vacuum line connection.
    it is not totally necessary to have one, but this shows you what to look for if you choose to.
    even if you don't use one you do need to run a couple bolts in the holes with sealer to avoid vacuum leakage.
  11. Dyna88Kid
    Dyna88Kid
    Ok! So there's a dashpot, but what device is supposed to go into the water holes? Are they really just for useless bolts? Maybe I'm not understanding...
    GO OLDS '60!!!
  12. Dyna88Kid
    Dyna88Kid
    Not quite, I have it but I've not installed it because I have to splice two together. The one that is on my fuel pump is too small to thread into the carb and the one on the carb is too large to thread into the pump. That part should be easy, but, as I don't know much about engines in general, the rest of the connections will be confusing for me.
    I think I need a book...
    GO OLDS '60!!!
  13. Paul
    Paul
    Editor
    I should have spoken more clearly :)
    I was referring only to the two smaller holes because Tony, GOATROPER02, answered about the two larger holes.
    they take intake manifold bolts,
    like the rest of the manifold bolts they attach the manifold to the head.
    and they do need sealer on the threads
  14. Dyna88Kid
    Dyna88Kid
    More pictures of the holes I'm really wondering about ImageUploadedByH.A.M.B.1376231517.270048.jpg
    Just behind the temperature sensor
    And:
    If everyone agrees nothing goes in here but bolts and sealant, that's what I'll get. I want my car on the ROAD!
    GO OLDS '60!!!
  15. Paul
    Paul
    Editor
    this is not a topic that requires democratic resolution.
    it's science.
    and what Tony says is fact.
  16. Dyna88Kid
    Dyna88Kid
    Ok! That makes sense now. Should push "refresh" more often.
    Now all I have to do is:
    Get a fuel filter,
    Replace the fuel arm ***embly that goes inside the tank (and get a gasket for it)
    Put the tank on
    Connect the carb
    Seal some bolts.
    I'll see about getting a dashpot, but I think I may have to go without. Can I just get bolts and sealant from, say, true value, and close everything up, or will I have to find some special bolt on ebay and pay way too much for it?
    GO OLDS '60!!!
  17. Paul
    Paul
    Editor
    dashpot holes can take any bolt of the correct size,
    I use American made quality grade 8 bolts for intake
    a shop manual would be a wise investment
  18. Dyna88Kid
    Dyna88Kid
    I hope I didn't make anyone mad...
    GO OLDS '60!!!
  19. Paul
    Paul
    Editor
    hahaha
    not even close
    good luck and welcome all Rocketeers young and old
  20. Deuces
    Deuces
    It takes allot to make this ^^^^ guy's blood to boil...:D:eek::D
  21. d2_willys
    d2_willys
    from Kansas
    Good choice for an engine, 371 golden rocket! Suppose to be gold in color, looks like someone painted the valve covers with light blue. Now all you have to do is get rid of that slushbox Jetaway and get a real transmission, dual range hydro my boy!
  22. Dyna88Kid
    Dyna88Kid
    Actually, I'm told the 371 was removed and the larger 394 was put in thanks to the second owner :/
    Anywho, thanks to you guys I'm much closer to getting her running... Now all I have to do is hook up the carb correctly o_O
    Let's see how this goes...
    GO OLDS '60!!!
  23. Dyna88Kid
    Dyna88Kid
    Jumping my ****ped battery now! I've got to turn her over a bit before connecting everything to dump the **** fuel out of the lines. Once I've done that, it's just two small connections and we're good to go!
    GO OLDS '60!!!
  24. Bobert
    Bobert
    Get all the old gas you can out of the system including carburetor. My Olds was started twice on old gas and the third time bent a half dozen push rods because the old gas had varnished the valves immobile in the guides.
  25. Dyna88Kid
    Dyna88Kid
    I've rebuilt the carb, so that shouldn't be an issue. I'm going tomorrow to borrow a compressor so I can blow the entire system out.
    GO OLDS '60!!!
  26. Dyna88Kid
    Dyna88Kid
    Anybody have some pics of similar two barrels with the fuel lines?
    I'm still a bit confused about where a couple connections go.
    GO OLDS '60!!!
