Technical 1960 Ranchero inline 6 questions
Discussion in 'The Hokey Ass Message Board' started by AP Kustom, Oct 8, 2023.
  1. AP Kustom
    AP Kustom
    What spark plug gap do you recommend?
  2. gimpyshotrods
    gimpyshotrods
    With the small cap distributor 0.035".
    With the HEI 0.045"
  3. AP Kustom
    AP Kustom
    So a buddy of mine sent me this tech article on installing the 250. It can be done. But not on my car. Because of how heavily modified my engine bay is already. Being body dropped, the hood won't fit without cutting it, and I don't want to do that. I already re made the firewall, trans tunnel, and floor, for the c4 on the 200, and changing that would be a lot of work and would affect the fitment of the center console wich would be a big issue inside. I already pushed the radiator as far forward as I could to clear the fan on the 200, and it always ran cool. So it's a no go on the 250. IMG_20231025_231638_336.jpg IMG_20231025_231640_700.jpg IMG_20231025_231642_938.jpg
  4. AP Kustom
    AP Kustom
    Anybody in So Cal want a 250??
    THE FRENCHTOWN FLYER likes this.
  5. CSPIDY
    CSPIDY
    This sounds like a very fitting ending to a very interesting story
    AP Kustom likes this.
  6. Beanscoot
    Beanscoot
    That looks like a great reference book. Could you post a picture of its front cover?
    46international likes this.
  7. AP Kustom
    AP Kustom
    Beanscoot likes this.
  8. how do you install the belts??? thats really a squeeze
  9. gimpyshotrods
    gimpyshotrods
    Take the radiator out first.
    LWEL9226 and The_Cat_Of_Ages like this.
  10. sounds annoying, what if you throw a belt, need to take the rad out then?
  11. SS327
    SS327
    In that case the belt takes the radiator out!
    Ford has a better idea! GM builds it! And Chrysler races it!
    Toms Dogs likes this.
  12. G-son
    G-son
    from Sweden
    True, but in reality, how often does that happen if everything is healthy and mounted in the correct spot?
    You could see it as a reminder to change the coolant every few years, replace it whenever you have to drain it to change belt. It's a feature, not a bug! :D
    gimpyshotrods likes this.
  13. at least the coolant doesnt get a chance to get old haha
  14. gimpyshotrods
    gimpyshotrods
    I change belts annually, needed or not.
    This car has an alternator, AC, and power steering, which also drives the Hydroboost brakes.
  15. AP Kustom
    AP Kustom
    What is the correct firing order? Just want to check to make sure mine is right.
  16. Kerrynzl
    Kerrynzl
    1 -5- 3- 6- 2- 4 and the rotor turns clockwise
    This never changed for 200's, 221's, 250's , Aussie Crossflows, or Barra's
    AP Kustom and Cooon like this.
  17. RmK57
    RmK57
    Place a thin piece of cardboard between the fan and rad and see if you can finesse the belt out. Looks like enough room to me.
  18. gimpyshotrods
    gimpyshotrods
    Firing Order: 153624
    Front is #1.
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Most inliners learn this meme:
    1-5 too young
    3-6 too old
    2-4 just right
    Does anybody know of an inline six engine that doesn't use this firing order?
  20. Jack E/NJ
    Jack E/NJ
    from NJ
