Projects 1960 Studebaker Lark Gasser
Discussion in 'The Hokey Ass Message Board' started by Hightone111, Jul 8, 2010.
  1. Six Ball
    Six Ball
    from Nevada
    The Studebaker Racing site and the Studebaker Drivers Club site have lots of real information from guys that have a bunch of experience with these engines.
    Hightone111 and loudbang like this.
  2. Hightone111
    Hightone111
    It’s still “knocking”, but I’m still driving it. The noise sounds to be coming from the top of the timing cover. I’ve inspected the oil psi relief and made sure the hole was clear. I did have the piston in backward (if it matters).
    I checked it over fairly thoroughly with a stethoscope and couldn’t really hear it anywhere else. I’m wondering if it is crank endplay? Would I hear that in other locations though?
    justanotherguy, loudbang and Six Ball like this.
  3. JC Sparks
    JC Sparks
    from Ohio
    You might not have rod end play if the piston was in backward.
  4. Mike VV
    Mike VV
    from SoCal
    As you know, there is nothing at the top of the timing gear cover.
    Other than possibly the plate that holds the cam is is loose, and the cam is moving back and forth.
    I finally got my Stude manifold done -
    It was originally a small Chevy V-8 intake. Heavy modifications both inside and out to work (hopefully !) on my 299 inch Stude.
    Mike
    brEad and Hightone111 like this.
  5. Hightone111
    Hightone111
    I’m really dreading tearing all apart, but I need to eventually. Hopefully it’s something simple like that.
    Cool intake btw! I’ve never seen anything setup like that.
  6. Six Ball
    Six Ball
    from Nevada
    I agree with Mike about the cam plate. It could also be the fuel pump. Is yours a Stude pump or did you do the modified Chrysler pump that Jake and I tried? That's the one that quit a little past Gold Field on the first Texas trip.
  7. Hightone111
    Hightone111
    Electric pump. So count that out
  8. Mike VV
    Mike VV
    from SoCal
    Thanks. I just hope it works like it looks. I have a single four barrel top too.
    Hightone -
    I know you said that you have an electric fuel pump, did you install the eccentric on the end of the cam ? Like was said, could possibly be the eccentric flopping around too.
    Mike
  9. Hightone111
    Hightone111
    It has been years since I ***embled the motor, but I did have intentions of running a mechanical pump so that is a possibility. Guess I could pull the block off plate to inspect inside there first?
    Six Ball and loudbang like this.
  10. Bearcat_V8
    Bearcat_V8
    from Dexter, MI
    What water pump do you have in it. There different impeller depths out there. If you have the wrong one, or even over torque a standard pump, the impeller can contact the inside of the coolant manifold and cause the noise you are hearing. Check the link below.
    https://studebaker-info.org/Tech/Cooling/WPC1/wpc1.html
    raprap, Hightone111 and loudbang like this.
  11. Hightone111
    Hightone111
    I imagine I’d hear that in the water pump/manifold. It’s got the Avanti pump.
  12. Jessie J.
    Jessie J.
    Did you check to see if the pipe plug in the distributor tower is in place? There have been many occasions where shops/builders have overlooked replacing this vital plug after the cleaning the oil galleries.
    This huge internal leak if present results in abysmal oil pressure.
  13. Jacksmith
    Jacksmith
    from Aridzona
    Wonder what happened???
    Surfcityrocker likes this.
  14. Dick Stevens
    Dick Stevens
    It's been a year since the OP was last on the HAMB
  15. Mike VV
    Mike VV
    from SoCal
    Haven't seen him on any Stude sites either.
    The Drivers site, or the Racing site.
    Mike
  16. Six Ball
    Six Ball
    from Nevada
    He is working hard keeping his shop open. I haven't seen him in a while. I'll check on him.
