Customs *** 1961 Cadillac CDV Kustom build ***
Discussion in 'The Hokey Ass Message Board' started by Ian Berky, Feb 11, 2011.
  1. Brain
    Brain
    from Kansas
    I know someone with 4 perfect 61 caddy caps
  2. 76formulafiend
    76formulafiend
    now that is some funny ****
  3. BenDaPirate
    BenDaPirate
    Looks amazing!! What's the trunk latch out of?
  4. MIKE P.
    MIKE P.
    Man it just keeps gettin better!
  5. Dirty54
    Dirty54
    Chuck Grell Streeter chrome in riverside ca 1 714 492 6302 charged me a 1/4 of what oher guys wanted to do my grille
  6. spot
    spot
    from usa
    All I can say is wow! You get more done in a day than I can in a week. Beautiful work. Looking forward to the sheetmetal brake info as well.
  7. 40StudeDude
    40StudeDude
    Yeah, I NEED a sheet metal break (correct spelling of that word-cuz you 'break', or fold, the metal, you don't 'brake' it), been trying to find one for some time, but they are all too damned expensive...I'm looking forward to that tech...
    R-
  8. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    It actually is a sheet metal BRAKE. As in Cornice Brake, Box-and-Pan Brake, Press Brake...
  9. Griznant
    Griznant
    Yeah, I'm not too sure about that.
    I just bought a new Accurpress 320 ton x 12' Press Brake, Model 732012 and all their literature clearly calls out "BRAKE". All the other brake presses we have are the same way. I've never even seen it spelled "break" unless it was a spelling error, and even then, NEVER by a manufacturer.
    http://www.accurpress.com/
  10. pwschuh
    pwschuh
  11. Ian Berky
    Ian Berky
    Thanx so much guys..... I'm speechless!!!! Been working my *** off on the Cadillac in my ****ing brutally hot garage and been making some progress , but a much slower pace!!!!!:(
    Hey Skip :D, Ill be there in the morning for a little while but not the whole day.... SEE you there????
    Hey Brian, sorry i haven't been a really good friend and haven't returned you call......Lame on my part!!!! Been so caught up in my own little world, but still no excuse!!! love you brother!!!! Let me know if you wanna sell the caps, i decided on running the caps over all the other options!!!!:)
    for those who don't know "" BRAIN"" is the awesome KANSASIAN who gave me the Cadillac!!!!
    Progress pics coming in the next few minutes!!!!:)
  12. Nads
    Nads
    from Hypocrisy
    It's amazing how very few will even know the *** end was veed.
  13. Ian Berky
    Ian Berky
    So after about 10 days of work on the rear..... I wasn't happy so i decided to cut all the **** out and start over again!!!!! **** HAPPENS!!!!
    First i tackled the inner structure on the lid.
    Then went to the local yard to find a GOOD trunk latch. The ONLY all metal latch i could find was out of Ford Probe, it came with the cable and release mechanism. 12$[​IMG]
    So then i started laying the round rod to create the structure and gaps.
  14. 40StudeDude
    40StudeDude
    Well then...what the hell do I know (obviously not much about sheet metal BRAKES...!!!)...??? Maybe that's why I can't find a good one cheap.:rolleyes:
    That's gotta be the most contradictory word I've seen in a long time and I stand corrected...thank you all for enlightening me.
    OK Ian, NOW I'm really waiting for your tech on the $42 brake...
    Oh, BTW, the trunk area is looking ***s...
    R-
  15. Ian Berky
    Ian Berky
    Then I tackled the rear pan.
    I don't have a BRAKE so after looking at different ones online and HOME TOOL TECHS, I went to the local metal supplies in the S**** pile and bought all the materials for less than 50$
    I really don't think i'm reinventing the wheel here, or trying to show my how smart i am... Take it for what it is!!!!!
    It works amazing with 20 g, and with 18g it's a slightly rounder bend, but still works great for i need to do here on this project!!
    Got some 1/4" x 3" angle iron , 2 pieces of 48" long and a few heavy duty hinges.
    tacked the hinges in place, where i thought the angle iron would get the most motion.
    then placed the other piece on top, FLUSH with the bottom one , NOTE that the hinge is lower on the bottom piece.
    now for the top piece it's again 1/4 " angle iron, 3 x 2 x 48. the 2 " part is the section that is vertical, for longer motion when you bend but still get the strength so the brake doesnt flex on thicker gauge metal.
    welded some HEAVY gauge tubing for the handles
    So here's a very important part of this how to... your top piece ( 3"x2" ) HAS to have a beveled edge or your brake will work like ****.
    so i clamped a guide and ground down a 45 degree edge.
    welded a tab in the rear center and drilled right through all the pieces and my work table. the 2 side bolts will hold my metal pieces before i bend to keep the metal from moving, sliding ,etc....... BEFORE YOU DRILL THE HOLES PLACE THE TOP BAR AGAINST THE BEND AND GO FULL MOTION , BY THAT POINT YOU'LL KNOW WHERE THE TOP PIECES NEEDS TO BE. TACK IT, DRILL THE HOLES!!!
    and you're done. the piece in the background is 18 g. perfect for extending bottom fins!!!!!;)
    Not rocket science but it works great for the small home operation i have here!!!!!
  16. Ian Berky
    Ian Berky
    Oh I forgot.... If you put a THIN layer of lubricant on the metal you are bending , you eliminate METAL TO METAL friction and makes it much easier to bend. Just saying!!!!:)
    here's the rear pan i did with the brake.
  17. Ian Berky
    Ian Berky
    Then i got sick of looking at the rear so i moved on to the bottom fins.
    i'll get back to it a little later and roll the rear section on the wheel, and finish the grill insert area.
    My knees and back are killing me from working so low on the ground.... I totally forgot that i do own jack stands.... :eek:
    More to come soon!!!!!!
    Thanx for watching!!!!
  18. 40StudeDude
    40StudeDude
    Here's a really off-the-wall suggestion, Ian- after looking at how you extended the fins on the bottom...and then you had to extend the bumper...I'm wondering how it would look if you had duplicated the taillight in the bottom fin...???
    I said it was off-the-wall...!!!
    R-
  19. Incredible. Great eye for the lines.
  20. Ian Berky
    Ian Berky
    Yesterday i played around with the extended fin and drew some lines to mimic to top fin and it was WAY TOO SHARKY!!!! I felt it made the car lose the space age feel i'm trying to create . Trust me, I thought about some options and i think sometimes less is more?!?!?!?! It's already so busy in the rear, i think, that the fins will just be extended, for proportion purposes only. Thanx though!!!:)
  21. K13
    K13
    Looks great Ian!
  22. Foppa
    Foppa
    i will say it once more, such an awesome build...
  23. Blackmaria60
    Blackmaria60
    ~ or ~
    "How to Make a Beautiful Car Stunning"
    By: Ian Berky
  24. shoebox1950
    shoebox1950
    Wow, Ian...this Caddy gets better with every update...I really like the extended lower fins and bumper edges. Can't wait to see it all together and rolled outside.
  25. Ian Berky
    Ian Berky
    Thanx so much guys!!!! :)
    It'll be rolled outside on the street very soon, I CAN'T WAIT..... It might look like ****..... who knows??!?!?!?!?!
  26. pwschuh
    pwschuh
    There is exactly ZERO possibility of that happening.
  27. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    Man, this is just killer! Reminds me of the back of a paper airplane!
  28. big creep
    big creep
    looks good to me!
  29. Mr.Musico
    Mr.Musico
    from SoCal
    love it, great stuff.........
