Customs 1961 Cadillac Chop...
Discussion in 'The Hokey Ass Message Board' started by Yaril, Jan 23, 2012.
  1. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
  2. KustomCars
    KustomCars
    from Minnesota
  3. Yaril
    Yaril
    since the last update... the firewall was painted along with the motor and body was put on the frame. now the body shop that i hired to do the job decided to close shop and i decided to pull the car out before **** hit the fan. now its up to me to finish the body work and paint job.
    started by blocking the car with the long file 120 grit and some hand blocking 150. they did a terrible job with the high build primer, it was real tough to get smooth, but i got it. body worked a few areas that they missed and now im ready for the next round of block sanding. but before i get any further i want to tackle the brakes and all other mechanical work so the car will be turn key again.
    the body color is on the firewall, not shown here but the body will have a platinum pearl mixed into the clear on the first coat.
    the lines on the car are very nice and panels are straight, some fine tuning and we should have body color this month on. i spray self etching primer on areas that went through to metal to protect it and the rest is a lacquer guide coat.
    thanks!
    Yaril
    kidcampbell71 likes this.
  4. Yaril
    Yaril
    finally got some color on this thing! its only base coat, more to come later. took a while cause i went ahead and took care of all the mechanical work first and fine tuned some more body work. but its finally in color.
  5. chaddilac
    chaddilac
    WOW!! dig that blue!!!!
  6. Yaril
    Yaril
    ok so here is what i did... the car was "ok" but i decided to go ahead and sand it back down with some 800 to get the paint a little "smoother" so today i covered the complete car with more of the same blue base (including the white fades), then i went back over and made new white fades / highlights. the fades are also carried into the door jambs. then i attempted to add some darker blue to the rocker area, but it look like ****. so i decided less is more in this case and made the rocker the baby blue again.
    mixed up a lot of platinum pearl on the first batch of clear, then 2 more heavy coats of clear without the pearl. these 2 coats ill use to give it a wet sand and buff.
    its really hard to capture the pearl in the pics, but in person it is neat to look at. cant wait to see it in the sun.
    roof work will begin this week. white flake base will be first.
  7. poorboy
    poorboy
    looks awesome! keep the updates coming!
  8. Tacho
    Tacho
    How much trim?
  9. Looks great. I think i remember seeing that Caddy at the Pomona Swap meet a while back.
  10. KustomCars
    KustomCars
    from Minnesota
  11. 'Mo
    'Mo
    The fade looks great! You have a really steady hand!
  12. scrape53
    scrape53
    from iowa
    that is so far beyond what he came with...increadible!
  13. Yaril
    Yaril
    thank you guys! im glad you all like it. again the pearl in person adds a lot to the paint job. yes this car was at pamona about 1 year ago. im very lucky to have a customer that has given me a lot of freedom in how the car will look. the interior is going to be just as neat as the exterior.
    thanks again
  14. surfcaliforniasurf
    surfcaliforniasurf
  15. koolkemp
    koolkemp
    Fantastic Yaril !
  16. shoebox50
    shoebox50
  17. Yaril
    Yaril
    got some more paint done tonight guys...
    well this is what we started with... again i wanted something "simple" but just a box with boarder wasnt enough for me... so i added a couple scallops into the design...
    then i masked off the white and stretched the lace that my grandma gave me... she already knew what i was going to use it for
    i mixed up some oriental blue and sprayed it through the lace a couple times, pealed the lace off and coated the area a couple more times. then some burple was mixed up for darker edges, both form house of color. now im still getting the hang of this stuff so its not perfect but each time i learn something new...
    unmask everything and begin to cover it with clear. i try and not reduce the clear at first so it lays on thick, then the last coats i reduce to stretch them out. i will be sanding it down tomorrow afternoon to see how the edges are doing, then i will decide if reclearing is in order.
    hope you all like it.
    kidcampbell71 and KCsledz like this.
  18. Brog
    Brog
    Hooolllllllyyy ****, this is gonna turn out good
  19. guitard
    guitard
    Good God man, that's slicker than snotty marbles!
  20. EnragedHawk
    EnragedHawk
    from Waco, TX
    Wicked man. Very cool.
  21. 1951Streamliner
    1951Streamliner
    from Reno, NV
  22. jwl53
    jwl53
    from So cal
    Looks great man... Love the color combo.
  23. 60galaxieJJ
    60galaxieJJ
    that lace job looks like the "may cause dangerous" 60 starliner that KIRK! did with gambino.
    loving this thread keep it up
  24. Nads
    Nads
    from Hypocrisy
    Can't wait to see it in real life
  25. lawman
    lawman
    That is like Soooooo nice !!!!!
  26. ph8ed4life
    ph8ed4life
    from AZ
    Good work! I think your eye for the chop is dead on ;)
  27. chaddilac
    chaddilac
    Nice job Yaril!!!! Looks great!
  28. leadsled
    leadsled
    looking good, I love the paint job on the roof
  29. gr8ness13
    gr8ness13
  30. bill s preston esq
    bill s preston esq
