1963 Lincoln Trans Issues
Discussion in 'The Hokey Ass Message Board' started by noxided, Feb 10, 2013.
  1. noxided
    noxided
    1963 lincoln 65000 original miles
    im rebuilding the motor as of now
    car sat for 20+- years
    The transmission wasnt shifting gears or letting me even get to a higher speed when i first started driving the car.
    The more often i drove it the better it would get, eventually to freeway speeds, but still not like it should
    does it just need to come apart and clean all the parts or most likely would there be damage?
    also has fresh fluid and filter.
  2. txturbo
    txturbo
    buy a can of TransX.....dump it in there and drive it. Rubber seals and o-rings get hard with age and leak so you don't get full fluid pressure where you need it. The TransX will soften them up and it should start working correctly if thats all it is.
  3. drewsifer714
    drewsifer714
    This is a '63 continental correct?
    There's a part, iirc called the transmission modulator,
    its vacuum controlled. If its bad or you aren't getting a good vacuum signal, you'll have trouble shifting.
    I just went through a similar issue, mine turned out to be a combination of bad vacuum lines and just my own stupidity. I was driving in the wrong gear, but I just couldn't get into third.
  4. 40FordGuy
    40FordGuy
    Ditto, #3. That modulator needs manifold vacuum, to function correctly.
    4TTRUK
  5. saltflats
    saltflats
    from Missouri
    If I hade the engine out I would rebuild it for sure
  6. Reijer
    Reijer
    Use ATF type F. Get a Maintenance Manual to troubleshoot & service the ****** and/or take it to a reputable shop. This PCA transmission has it roots in 50's Ford transmissions but has nothing in common with the C6.
