1963 Muncie M21 Four Speed
Discussion in 'Parts For Sale' started by MEJ1990TM, Nov 28, 2016.
  1. MEJ1990TM
    MEJ1990TM
    City: Chino Valley
    State: Arizona
    Price: 750
    For sale is a 1963 dated Muncie M21 four speed transmission. Overall this transmission is in very nice condition. It is also somewhat rare in that it is a one year only casting case. The "1704" casting was a first year production only. In 1964 GM switched to the "325" casting. This trans has the 7/8" cluster gear pin. Unlike most transmissions of this era the cluster gear pin had a very nice tight fit. The information on the trans is as follows:
    Main Case- 3831704
    Side Cover- 3831707
    Tail Housing- 3846429
    Bearing Retainer- 3741458
    ***embly Code- P0401 (April 1st, 1963)
    Partial VIN- B212013
    This trans was taken completely apart, everything cleaned in a parts washer, and then re-***embled with new gaskets, seals, and tail housing bushing. The bearings that came out were in real nice condition. I also upgraded the synchronizer ***emblies in this trans. The original ***emblies had a thicker hub, but a thinner synchro ring. Those thinner rings were prone to cracking under hard shifting conditions. This trans has the later style thin hub/thick ring ***embly. The gear set is in real nice shape as well. There are no chips ,or breaks, and the engagement teeth show minimal wear for something that is over 50 years old.
    All this transmission need is to be filled up with oil and run. The link to pictures is below:
    http://s160.photobucket.com/user/MEJ1990TM/library/1963 Muncie M21 Four Speed
    Feel free to call, text, or message me with any and all questions. My name is Mike, and my number is (760)803-7240. If I don't answer please leave a message and I will get back to you as soon as possible. I also rebuild vintage manual transmissions, so feel free to inquire about that was well.
  2. MEJ1990TM
    MEJ1990TM
    Still available.
  3. MEJ1990TM
    MEJ1990TM
    Still have it.
  4. MEJ1990TM
    MEJ1990TM
    Still available.
  5. MEJ1990TM
    MEJ1990TM
    Still have it.
