Projects 1964 Falcon B/FX Build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 29, 2011.
  1. man that is looking sharp
  2. Thefalconkid
    Thefalconkid
    Thanks clay, it's gonna take me a few days to try it, my wife has me moving a fence in the back yard, an the company that installed it used enough concrete to do a whole driveway per post! I'll be digging all morning, then renting a jackhammer. Once I'm done moving the fence, I'll be sore for a few days, but I'll get back to the window as soon as I feel up to it. I'll be back soon with a update.
  3. fiveoh108
    fiveoh108
    A little progress today, finished routing the battery cables from the trunkto the engine compartment, starter silenoid mounted in engine compartment and I painted my msd coil to have a yellow top like the original coils.
  4. Thefalconkid
    Thefalconkid
    Clay, I guess it came out so easy because it's a new gasket. I pulled the gasket back from the roof with my fingers, dripped some dish soap along the top, and gently pushed it out all by myself. Put the trim on, then me, my wife, and my stepson put it back in. It was a piece of cake. Thanks everyone for the tips!
  5. Thefalconkid
    Thefalconkid
    Mike, the battery is so cool! Should be running soon?
  6. 65COMET
    65COMET
    Mike;any news on your Falcon? ROY.
  7. fiveoh108
    fiveoh108
    OK i think i just about finished all the wiring for teh MSD, new fuse panel, 2 step, line lock, coil (msd, just painted to look original), distributor and battery. I just need a small length of 1ga wire from the firewall to the starter silenoid, i ran out of cable... Also i need to run the wire from the fuel pump to a toggle switch in the drivers compartment. I was able to route the main battery cable though most of the wiring locations with a little size increase with my step drill bit and some rubber grommets. Everything should be hidden for the most part...
  8. paco
    paco
    from Atlanta
    Looking good ... not to far away from the fire on this one. Thanks for the on/off switch idea.
    PACO
  9. Thefalconkid
    Thefalconkid
    Looking really good!
  10. ec164
    ec164
    from MI
    I like the use of the FE tank in your cooling system, its looking good and your almost there, fire up time.....Al
  11. fiveoh108
    fiveoh108
    Got the hood fitted today and the hole cut, just glad everything lined up!! Now time to paint the bottom. I am going to do it the same black as the engine compartment.
  12. fiveoh108
    fiveoh108
    Trying to find a good place to mount the fuel pump switch. I figured I am not going to have a radio anyway, this will save me from drilling more holes and can't be accidentally hit while shifting or with a knee. Then I can just finish off the rest of the opening with some aluminum. Thoughts? Or where have you mounted yours?
  13. Thefalconkid
    Thefalconkid
  14. Thefalconkid
    Thefalconkid
    How about a radio delete plate? Then you could use one of the heater pull out knobs for the fuel pump? Hidden, and cool!
  15. fiveoh108
    fiveoh108
    My original idea was to use the lighter as my switch or the wiper switch, but I don't want it so hidden that I can't get to it quick enough if I need to. If you know where a delete plate is let me know I have been trying to find one forever!
  16. Thefalconkid
    Thefalconkid
    Does crites make one?
  17. fiveoh108
    fiveoh108
    Not for the deluxe dash.
  18. Thefalconkid
    Thefalconkid
    Man, I know they are hard to find for my car, I can't imagine how hard they are to find for yours.
  19. dirtbag13
    dirtbag13
    looking really good
  20. Muttley
    Muttley
    Try this guy, he repops a bunch of delete plates. I've got one of his heater delete plates in my Comet's dash and the heater core plate on my firewall............very nice parts.
  21. fiveoh108
    fiveoh108
    Thanks muttley, I have the engine compartment and heater block off as well from him. The last time I inquired a few months back he said he did not make the deluxe dash one and had no plans to in the future... The search continues!
  22. fiveoh108
    fiveoh108
    Headliner/ package tray and headrest pad done. Thank you again Roy for the trailer...and to my dad and roy for all the pushing!
    My driveshaft safety loop and my driveshaft safety loop installer.
  23. 65COMET
    65COMET
    Mike's daughter is a kick,she LOVES to talk and she is becoming some what of a car nut!!!!! Mike is really making forward progress now,it won't be long before that Falcon is flying!!! ROY.
  24. ec164
    ec164
    from MI
    Mike your headliner and head pad look great! Also glad to see you keeping your daughter in the loop....Al
  25. fiveoh108
    fiveoh108
  26. Thefalconkid
    Thefalconkid
  27. paco
    paco
    from Atlanta
    solid - good looking C-dan.
  28. 65COMET
    65COMET
    Mike;I hope you bought it!! Looks like it needs a rechrome,but it looks solid!!! ROY.
  29. fiveoh108
    fiveoh108
    Yea Roy I bought it. It's on it's way home! I got the car started today! It ran good Idled decent with 65psi of oil pressure. It did heat up after about 8 minutes and shot up to 200 degrees and was climbing until I shut it off. The radiator and expansion tank were kinda cool/warm but the block was hot. I have a 160 themostat.. I am thinking maybe the water did not get into the block, like a big air bubble? Your thoughts? I am just happy it ran and sounded good!
  30. Thefalconkid
    Thefalconkid
    160 is way too cold! It will never close, and the coolant won't stay in the radiator long enough to cool down. Use a 180, or somewhere around there.
