Projects 1964 Falcon B/FX Build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 29, 2011.
  1. Thefalconkid
    Thefalconkid
    Looks awesome mike!
  2. fiveoh108
    fiveoh108
  3. metalman
    metalman
    enjoyed meeting you and seeing the car, came out sweet. Man, they sure run you guys down early!
  4. paco
    paco
    from Atlanta
    SUCCESS! Looking good. Congrats on your efforts - you are an inspiration.
    PACO
  5. fiveoh108
    fiveoh108
    Some pictures my sister sent me today
  6. 65COMET
    65COMET
    Mike did great for his first EVER drag race,especially with a brand new car!! He has a few minor issues to deal with but he and his Falcon were doing great!! Never saw him without a grin on his face!!!! ROY.
  7. ec164
    ec164
    from MI
    Really am Happy for you Mike, your car looks great and your through your first race session!! The smile Roy saw tells me it was worth all the work pushing to get there(CHRR)....Once again Congrats......Al
  8. SOHC427
    SOHC427
    That car is stunning, in person.
    Mike, it was great to meet you, and I will get that parts washing stuff to you, asap.
    Had a fun weekend at the reunion, and look forward to doing it again.
    Eric
  9. 65COMET
    65COMET
    Eric;we have been drinking that stuff,thought it was the 'shine' you brought!!!! ROY.
  10. Thefalconkid
    Thefalconkid
    The car looks great mike! Glad you had a good time.
  11. 65COMET
    65COMET
    Mike;are you still basking in the excitement from CHRR? Have you done anything to the Falcon?Did you find your steering column nut? ROY.
  12. fiveoh108
    fiveoh108
    The steering wheel nut has vanished.. I ordered a new one and will get yours back... That I found.... is an important piece! Lol I parked the falcon after the race and have not started working on the things I need yet, maybe this weekend!
  13. 65COMET
    65COMET
    Mike;no hurry on the steering wheel nut,the wagon is a LONG way from ready,just making conversation!!! I've got parts ordered for the fuel system,they should be here Monday or Tuesday! I haven't checked the clutch,pretty sure it is linkage related as it seemed fine on that last p***!!I found a hitch drop that may work for you,found it while looking for something else!! ROY.
  14. Thefalconkid
    Thefalconkid
    How's it going mike? Anything new with the falcon?
  15. fiveoh108
    fiveoh108
    I am upgrading my cooling system right now. I got an electric water pump, new cross flow radiator and am currently working on finding an electric fan that will fit in the 2 3/4 inches of space between the two. I wasnt having major problems cooling, but I didnt like the moroso electric water pump kit drive.
    I got a new Z bar, that Roy helped me bend yesterday to fit my application. I would like to get some 8- 8.5 inch slicks, but I don't know if they will fit the stock wheel well, maybe with the right offset..
    I had an artist do a drawing of my car from the HotRod Renunion...take a look.
  16. ec164
    ec164
    from MI
    That looks good Mike, those pencil people are really good.....Al
  17. fiveoh108
    fiveoh108
    I took the intake off and resealed it as it had a leak. I also adjusted the valves since it is a solid roller cam. New 3 core radiator installed, new electric waterpump, new electric fan, new air pan instead of aircleaner and new alternator mount system. I moved the overflow can to the drivers side wheel well so it is not taking up realestate in the engine compartment. Now i just need to get my new wider slicks/ rims, then I should be ready for the March Meet. Hopefully I can break into the 12's
  18. 65COMET
    65COMET
    Mike;looks great!! I like the way the fan and shroud covers the entire core,should work great!!Did you get the clutch linkage worked out? ROY.
  19. ec164
    ec164
    from MI
    Looks good Mike, I like the air pan idea too! 8.5 inch rim with 4 inch backspace should work. 8.5 or 9 inch is a good size slick, what size you thinking?....Al
  20. 60srailjob
    60srailjob
    from nowhere
    now see I like that much more than my 63......way cool....
  21. fiveoh108
    fiveoh108
    Yes Roy I got the clutch linkage all figured out.. It seems pretty strong, I used that adjustable lower rod you gave me. I think I am going to try for the 8.5 slick on a steel 15x8 rim .. I think that will fit the wheel well, maybe a little inner wheel housing m***age will be needed.. Thank you for the compliment 60s
  22. Russco
    Russco
    from Central IL
    The wheelhouse should be big enough to fit an 8 1/2 inch tire. I was able to fit a 10" tire in the stock wheel house with only rolling the outer lip.(I did have to move the leaf inboard but the wheel house should be wide enough)
  23. Thefalconkid
    Thefalconkid
    Looks like a race car now!
  24. fiveoh108
    fiveoh108
    Got the car running, took it for a drive...AWESOME...no more valve train noise...other than the solid lifters, drops into gear like nothin, no more fighting a half engaged clutch. I have been wanting a switch panel to mount my fuel pump, water pump and electric fan on... I was looking at all the parts houses, but could not find anything I liked or fit my application so I started with this, a 64 glove box door I had...
    ***then did this
    ***separated the skin
    ***cut out some aluminum to box it in and drilled holes for the switches and lights, taped it together
    ***rivited everyting together
    ***and test fit it
    ***Now I just have to do a little wiring and decide how to paint it... I might do it the same to match the dash, since it is a dash piece... Also I have to install two mounting tabs to mount it to the floor
    Mike
  25. MUNCIE
    MUNCIE
    from Houston
    I like the way the box came out,looks great.
  26. fiveoh108
    fiveoh108
    Finished with a temporary ground wire for the lights.
  27. 65COMET
    65COMET
    Mike;I missed your call,left you a message,give me a call.Your new switch panel look good! ROY.
  28. paco
    paco
    from Atlanta
    Outstanding ride. Tha's all I can say.
  29. NewGuyOldFord
    NewGuyOldFord
    I'm a little late to this but what ever happened to the factory buckets and console? Did you sell them or are they for sale? Sorry for not reading the whole thread if this was already discussed but I saw the first page and the "replacement" seats and jumped here to ask. Thanks.
    Bart
  30. fordrule
    fordrule
    wow awesome build. I am picking up a 64 futura end of the month. thank you for some inspiration
