Projects 1964 Falcon B/FX Build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 29, 2011.
  1. fiveoh108
    fiveoh108
    Color sanding
    I think this is where the engine goes??
    and my door decal I am almost done reproducing with a sign company similiar to **** Brannan's Falcon
    (photo from ****brannan.com)
  2. Judd
    Judd
    Falcon is looking great. I like your engine builder/ballerina.
  3. 65COMET
    65COMET
    Judd;I think she is Mike's Crew Chief,keeps his *** in line!!!!!!
  4. fiveoh108
    fiveoh108
    Thank you guys, Roy someone has to monitor me!! I got that new distributor gear too, maybe I can stop by tomorrow if you have time?
    The color sanding and buffing is done, it's amazing how much that improves the look of the paint. You can see my tool box reflection in it now!
  5. 65COMET
    65COMET
    Mike,looks great!! Stop on by! ROY.
  6. fiveoh108
    fiveoh108
  7. 65COMET
    65COMET
    Lookin good!!!! ROY.
  8. wayne421
    wayne421
  9. fiveoh108
    fiveoh108
    These were hard to find with 289 on them, but they will match the decal
  10. novas4life
    novas4life
    from vnc,wa
    Such a RAD car....looks GREAT!!!
  11. wayne421
    wayne421
    Kool I've never seen any like that
  12. 6t5frlane
    6t5frlane
    from New York
    Who sells those ???
  13. fiveoh108
    fiveoh108
    If I tell you then I won't be the only one with them!?!
    Perogie sells them... I don't know how many they have because I had to speak to a couple different sales people, the first one said they were out, I called a week later then the sales person I got that time put me on hold and said was able to locate a set in the wharehouse.
    Good luck!
  14. wayne421
    wayne421
    I wish somebody made them for what ever cubic inch u have like some 532s would be great on my car
  15. fiveoh108
    fiveoh108
    What do I do here? I have a McLeod bellhousing and Doug's headers, but as you can see they don't agree with each other. Do I clearance the bellhousing and decertify the sfi rating or get some type of header flange spacer and hope it does not leak or hit the shock tower? And big thanks to Roy for pressing on my new distributor gear!
  16. 65COMET
    65COMET
    Mike;I would notch the flange on the bell housing.The tech guys will never see it,just take off enough to get the headers to fit flush with the heads!!!! ROY.
  17. Gasser1961
    Gasser1961
    How about a small spacer to bump the header out?
  18. fiveoh108
    fiveoh108
    Got the bellhousing problem fixed.
    This:
    Led to this:
    Which led to this:
    Which led to:
    Which is going to lead me to do some cutting! This is fun!
  19. 65COMET
    65COMET
    X2 on what Al says!!!!!Wish I could say it never happened to me,I would be lying if I did!!!!!Just a little trim on the pinch weld!!!! ROY.
  20. fiveoh108
    fiveoh108
    I modified a big block clutch fork to the shape of a small block fork. I have a big input shaft in my small block toploader so the big block fork was needed for the larger 1 3/8 input. The stock big block fork is about two inches longer and didnt line up right, nothing my angle grinder couldn't fix!
  21. fiveoh108
    fiveoh108
    Just about done detailing the trunk, painted everything the body color. The body shop left everything dynasty green including the hinges. I re-conditioned the fuel filler neck and gas tank vent hose. Painted the top of the gas tank black along with the back bars of the roll bar, re-wrapped all the tail harness/ gas tank sending unit wires, re-plated (with cad spray paint) the trunk striker and latch, even cleaned and re installed the factory seam guards on wheel wells!!
  22. 65COMET
    65COMET
    Mike;just my opinion,but I would paint the inside of the fenders flat black,it makes that under coat less visible by not being shiny!! ROY.
  23. Lookin good Bro!!!
    Fast Eddie
  24. 65COMET
    65COMET
    Mike;have you been able to work on the Falcon? ROY.
  25. fiveoh108
    fiveoh108
    I got the headers in last night but it was so tight On the drivers side, I had to unbolt the steering box and push it up outta the way, jack up the car about two feet then a little forcefully squeeze the header through the small opening created by the bellhousing and trans tunnel... I couldn't hold the headers ,steering box and z bar, now I have to figure a way to get the z bar in there.. I took a break tonight but will try to get that on tomororrow night. I am also going to try and get the intake mounted so I can see where the pinch weld needs to be clearanced and where I may have to do a lil grinding for the distributor to fit.
  26. fiveoh108
    fiveoh108
    So the z bar I had was too long so I cut it and welded to the proper length. Still got to finish welding it and try and get it installed. Here is my fuel filter and fuel pump bracket. I am going to drill two holes through the trunk floor and mount the bracket just in front of the gas tank probably with a bicycle tube or some other rubber between the bracket and the floor. The pump will be lower than the gas tank by about an inch. Trying to keep it clean and simple, hopefully this works!
  27. paco
    paco
    from Atlanta
    Super build.
    Having a '64 fairlane sedan that I'm collecting parts for I dig all your hardships & rewards.
    Kewl *** build.
    PACO
  28. fiveoh108
    fiveoh108
    Got the fuel pump/ filter bracket mounted. I used a couple rubber grommets and drilled out the center so the mounting bolt would slide through... Trying to stop the interior reverberation from the pump. Also the pump to the bracket has rubber grommets so hopefully it will be kinda quiet.
  29. wayne421
    wayne421
    hey is that base clear or single stage in your trunk . the guy at my body shop told me to single stage my trunk ,engine comparment and interior
  30. fiveoh108
    fiveoh108
    That is base coat clear coat out of a spray can. I didn't have the body shop paint the trunk or engine compartment. The engine compartment is single stage from Eastwood under hood black. I used VHTs glossy rollbar black for my Rollcage and VHTs semi gloss black for all my interior panels (doors, dash and rear quarter pieces), the VHT paint lays out super smooth and is good for the flat panels. For The trunk I ordered 3 dans of paint from automotivetouchup.com the same factory color as the car and a can of clear.
