Technical 1965 F100 clutch modification?
Discussion in 'The Hokey Ass Message Board' started by 61unib100, Mar 7, 2024.
  1. 61unib100
    61unib100
    from Alpine, Ca
    Hey all. I recently broke my clutch down rod on my 1965 F100 and of course it’s the year that isn’t reproduced. My question is does anyone know where I could locate one? Or should I fab something up with heim joints? Or go cable? If anyone has suggestions please let me know.
  2. If it broke at the '90' on one end, just weld 'er back together. That's what I did on mine, worked for another 100+K miles...
    RMR&C and Algoma56 like this.
  3. 61unib100
    61unib100
    from Alpine, Ca
    Yeah it broke at the 90 inside the cab. Not sure if I lost any other parts off the bell crank but I guess I’ll find out. Thanks for the reply.
  4. Mike Lawless
    Mike Lawless
    The F100 clutch rod is easily replaceable with a rod and a couple heim joints. Not only can it be adjustable, it can smooth the actuation.
    Truckdoctor Andy and Algoma56 like this.
  5. 61unib100
    61unib100
    from Alpine, Ca
    Thanks for the tip! I was hoping to hear something like this
  6. Mike Lawless
    Mike Lawless
    I should have pointed you to post #50 on my build post. (Use the link below).
    Has a photo of the rod rod end on the linkage rod. 3/8" rod ends. Needs a washer where it bolts to the arm for rod end body clearance.
    ekimneirbo likes this.
  7. 61unib100
    61unib100
    from Alpine, Ca
    Hey Mike I don’t see the link. Can you try and post it again please. Thank you!
  8. 56don
    56don
    Is any of this what you need?
  9. Mike Lawless
    Mike Lawless
    Right below in red. Where it says
    Ol' Furd.....
  10. Toms Dogs
    Toms Dogs
    from NJ
  11. pprather
    pprather
  12. deathrowdave
    deathrowdave
    from NKy
    Go to a local spring shop , get the correct length of threaded stock before they bend for a u bolt . 2 Heim joints , stick a fork in it your done .
  13. 61unib100
    61unib100
    from Alpine, Ca
  14. Mike Lawless
    Mike Lawless
    Thanks pprather. I did not know the link doesn't come thru when viewing on a phone.
    The rod I used is 3/8" steel straight from the tractor supply. I do have the means to easily cut threads for both left and right. Right hand thread on one end, left hand thread on the other so all you have to do is turn the shaft without unbolting from the arms to adjust. That is not necessary though. With right hand threads on both ends, it's still adjustable, but you would need to disconnect one end to lengthen or shorten the rod.
    pprather likes this.
  15. 61unib100
    61unib100
    from Alpine, Ca
    Thank you Mike! Looks good all the changes you did to the clutch system.
    Mike Lawless likes this.
  16. 56don
    56don
