Projects 1965 Nova SS
Discussion in 'The Hokey Ass Message Board' started by John 79, Jul 4, 2012.
  1. John 79
    John 79
    from Sweden
  2. John 79
    John 79
    from Sweden
  3. John 79
    John 79
    from Sweden
    Click on the pick!
  4. KustomCars
    KustomCars
    from Minnesota
    That is awesome!!!
  5. John 79
    John 79
    from Sweden
    Thanks!!!!
    Just a lame 305 but it its strong enough to smoke the slicks and i got a BIG smile on my face :D
  6. HOTRODPRIMER
    HOTRODPRIMER
    I couldn't seen the grin for all the smoke,,but I KNOW you had to be grinning ear to ear! :D HRP
  7. John 79
    John 79
    from Sweden
    Yep,and im still smiling.
    Its a ****ty lame car but it sounds tough and smokes the tires and thats enough for me ;)
  8. Gizzy
    Gizzy
    from N.W,Ohio
    Looks like your having fun....good job!
  9. swade41
    swade41
    from Buffalo,NY
  10. Fugly Too
    Fugly Too
    Bror! If that's a "lame" small block, I wouldn't want any part of your "big motor" when you get to build it!
    Your build is impressive. Fruktansvard!
    If you come to visit, tell us. FESTA!:D
  11. AHotRod
    AHotRod
    Great burnout John, just like we did in the '70's !
  12. 70L34
    70L34
    from Detroit
    Nice work. The floor pan looks pretty rust free!
  13. John 79
    John 79
    from Sweden
    There are some old repairs in the floor that looks alittle ruff and some rust where the floor connects to the firewall.
    The floorpans are not great but not all bad either ;)
  14. John 79
    John 79
    from Sweden
    Got the back and frontseats in.
  15. John 79
    John 79
    from Sweden
    The Nova has now p***ed tech inspection and is legal to drive.
  16. theman440
    theman440
    from Las Vegas
    Let 'er rip man!
  17. John 79
    John 79
    from Sweden
    Yes sir,will do :D
  18. John 79
    John 79
    from Sweden
    Took the windshield out,had some rust in one of the corners and im also getting the roof down to bare metal and needed access around the windshieldrubber.
  19. John 79
    John 79
    from Sweden
    Did some more metal work today.
    Took off the outer plate to get to the inner rot.
    as you can se on the pic there is a space between the 2plates from factory so water and all kind of **** can get right in.
    Rot in the upper side that started it all.
    When i removed the outer plate i found this under.
    I knew i had it coming :D
    Some new metal welded in,all this will be covered with Another outer plate later on.
  20. John 79
    John 79
    from Sweden
    Inner structure of the a-pillar is done.
  21. John 79
    John 79
    from Sweden
    Made a new outer plate today,the old one was to bad to fix.
    Som test fitting and then the welder did the rest.
  22. John 79
    John 79
    from Sweden
    Got the roof down to bare metal after grinding down 6 layers of paint.
    Then i took out my "spray gun" and now the roof has some grey Zink primer like the rest of the car.
  23. John 79
    John 79
    from Sweden
    The roof is done.
  24. John 79
    John 79
    from Sweden
    Some minor stuff done.
    Changed oil/filter in the trans and also changed the oilpan for the trans.
    Trew the Summit aircleaner away and bought a "scoop".
    Also thinking of this,anyone tryed these?
  25. waterhorse
    waterhorse
    We put a new 350 in my son's '65 hardtop last year, boy these Novas are tight under the hood to work on. Bur way cool.
    Greg
  26. John 79
    John 79
    from Sweden
    Yep,its a bit tighter the fullsize cars but alot lighter.
  27. John 79
    John 79
    from Sweden
    Got my ball joint spacers today,will mount them later today so stay tuned ;)
  28. 1971BB427
    1971BB427
    from Oregon
    Check the clearance on the ball joint spacer to the frame on full frontend lift! Sometimes the spacer will touch the frame when the front is raised, and eventually break the spacer if not clearanced. Also will need stronger coil springs if you're using the spacers to get the frontend up higher.
  29. John 79
    John 79
    from Sweden
    Will do sir!
    I got stronger front coils alredy but on Novas the coil is located ontop of the upper Control arm so it will work out anyway.
  30. coolbreeze1340
    coolbreeze1340
    from Indiana
    I love Novas! I had a 64' 2-door post years ago with a 327 and it is one car I wish i kept!
