1965 Riviera P/S Pump
Discussion in 'The Hokey Ass Message Board' started by Richard D, Jan 20, 2012.
  1. My friend was doing some work under the hood and saw a big leak where the hose fits. Said the fitting was tight. Any ideas? Is there an O-ring in there?
  2. Dane
    Dane
    from Soquel, CA
    It looks like an inverted flair in the pics I see for replacement parts. The flair ends can get crushed after a few times being installed and then removed. I'd just get a new one for $12 at RockAuto.com. If it still leaks the problem is in the pump. You can look at the fitting on the pump to see if there is a groove worn into where the flair should seal.
    http://www.partstrain.com/store/det...er_Steering_Hose/1965/Gran_Sport/EP71306.html
  3. SIC98
    SIC98
    Yea, mine is leaking there as well, tried putting a generic o-ring on it, but no go it leaks worse, thanks Dane for the link, just ordered my new hose at $18 can't beat it!
