1966 300hp 327
Discussion in 'The Hokey Ass Message Board' started by 440 deluxe, Jan 20, 2013.
  1. 440 deluxe
    440 deluxe
    I got a 66 327 in my coupe. Im running a ac spark plug #45. Not real happy with them. Seems like I have a lazy one in the bunch. Any advice on a different plug? thanks
  2. brigrat
    brigrat
    from Wa.St.
    One out of 8 ain't bad buy another plug!
  3. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I run AC Delco 45S plugs in my 327's. No issues.
  4. Deuces
    Deuces
    Could be a bad plug wire also... You might want to check it out..... If not, then switch over too what VooDoo is running...
  5. HOTRODPRIMER
    HOTRODPRIMER
    I have a 1963 300 HP 327 in my Deuce pickup and use AC 45S plugs,,no problems at all.
    I also have a flamethrower coil. HRP
  6. lawman
    lawman
    Have you tried the 44s?
  7. mxwge
    mxwge
    dont know if they still make them ac used to make a c45 plug.the c prefix indicated a commercial plug. they worked well for me.
  8. 440 deluxe
    440 deluxe
    thanks for the input. ill hunt down the lazy one and swap it out and see what i get. Ive always ran ac plugs and they always worked good too. maybe im just getting lazy!!
  9. big duece
    big duece
    from kansas
    Make sure you dont have a crack in the rotor cap on that cylinder, carbon build up on the crack will try to fire two cylinders at once.
  10. nwbhotrod
    nwbhotrod
    from wash state
    Is it from a Corvette
  11. big duece
    big duece
    from kansas
    Aren't they all from Corvettes?
  12. Deuces
    Deuces
    only by what's stamped on the block.... Everything else is the same.... But I'm sure you knew that...:D
  13. big duece
    big duece
    from kansas
    Didn't realize vettes took special plugs.:D
  14. [​IMG][​IMG][​IMG][​IMG][​IMG]
    On a serious note...........
    Dump 'em, put a set of NGK's in and never look back.
  15. brigrat
    brigrat
    from Wa.St.
    Swap cylinders with the "lazy" plug with a known good plug, that will narrow down if it's the plug, plug wire, bad cyl., cap, etc.
  16. LOST ANGEL
    LOST ANGEL
    Everything from a Vette is special, especially the price!!-MIKE:eek::D
  17. Use the NGK V Power, V is for Vette ;)
  18. chopolds
    chopolds
    from howell, nj
    Did you pull the plug yet? SBC's are renown for leaking guides, and they'll foul a plug in a hundred miles.
  19. 68vette
    68vette
    For all the na-sayers of those that say they have a 327 out of a corvette....
    I don't know about you....but so so many vettes for sale say in the ad....NON-MATCHING ENGINE NUMBER CAR.
    Now just where do you think those engines went to.....327 Vette heaven?
    When the very few on here say they have a SBC out of a vette....it just might be the truth....I know my engine number matches the VIN number but so many do not....watch even Barrett-Jackson and Me*** and see how many of those vettes don't have a matching number....those engines went somewhere....
    And a ford is the only car I have ever had to use anti-fowlers on...
  20. slammed
    slammed
    Got a mid '60's vette motor in a ral SS 1969 Camaro. Heads one year, block another. And the intake is a 1966 HIPO Nova unit. They out there, chuckles.
  21. Yea right! :rolleyes:
    There have been many numbers re-stamped and the bulk of it has been done to plastic Chevies. ;)
    Reality TV... Now there's a litmus test. :rolleyes:
    Yea, every Hot Rod, Camaro and Chevelle ever built! :D
    You must live a sheltered life wearing those rose colored gl***es. :rolleyes:
    Fact: According to sellers of Chevy powered cars, there are more vette engines out there than vettes made.
    Fact: GM traditionally has had the worst valve seals and valve guides of any manufacturer making it more likely to use anti-foulers.
  22. TagMan
    TagMan
    I REALLY DO have a Corvette 327 engine. I helped remove it from my buddy's '64 vette. It might not have been ORIGINALLY in a Corvette, but I can honestly say it's out of a vette ! :D
  23. 5559
    5559
    from tn
    autolite 303 i've had them in some really bad smokers & they are hard to foul
  24. I know that my 327/300 hp came out of a 63 Impala SS &
    I use NGK plugs with No Problem for the last 25 years
    just my 3.5 cents
  25. slowmotion
    slowmotion
    Autolite man, myself.
  26. CJS
    CJS
    Back in the day we looked for a few clues if someone claimed the engine came out of a Vette. The oil pan could be a different shape, side motor mount holes not used with paint still on the bosses and threads.. Early Vettes used a front motor mount sandwiched between the water pump and block. Vette motor used Morane 500 rod and main bearings.[stamped on the bearing backside] The rest used morane 400 bearings. Trucks also used morane 500 bearings but the block would be painted gray. There were also many other small differences. Some of you old timmers are saying "O that's right, I remember that."
  27. eppster
    eppster
    Good to see you posting Curt !!! Taking time from your Casino adventures ?
