1966 C-10 - Transmission Help - SM420 to T5 swap
Discussion in 'The Hokey Ass Message Board' started by 63ChevyII, Dec 18, 2007.
  1. jerry
    jerry
    Mounting pattern sure looks like a chevy pattern. The spline count is the 1 1/8 26 spline camaro style. Matching clutch is available in either 10 1/2 or 111 inch IIRC. The later muncie used the same spline.
    The casting numbers on the housing can be the same between different final ***emblies.
    Should be no prob;em putting this in your chevy II
    jerry
  2. 63ChevyII
    63ChevyII
    So after doing some more searching around, it turns out that I won't be able to use this tailhousing.
    The seller/and or builder ripped me off! The tailhousing is the electronic unit. The hole is pointed directly at the speedo gear.
    I tried calling both the seller and builder and of course, got no answer. Which ****s... I can't just drive over there, they're from Texas.
