Technical 1st Gear Violent Shaking
Discussion in 'The Hokey Ass Message Board' started by mykeb, Apr 17, 2014.
  1. bobss396
    bobss396
    I once bought a remanufactured clutch set from a local place called Economy Clutch in 1976 or so. The $$ was right at the time, but it was never a strong enough clutch for the C30 truck it was in. Eyeball wise, it matched the old one 100% and was all nice looking.
    Lesson learned.. don't cut corners on driveline parts.
    Bob
  2. mykeb
    mykeb
    from Virginia
    Thank you Squirrel, HotRodPrimer, and Stu D Baker.....
    crawled underneath the truck this afternoon to pull the inspection cover to see if there was oil on the flywheel. There very well may be and I'll save that check for a different day. Only because Squirrel, HotRodPrimer, and Stu D Baker mentioned it, I reached up to verify the p***enger side rear engine mount bolt was tight......it wasn't. In fact, it was loose enough that I could turn it with my fingers.
    The driver side wasn't nearly as loose, but it too is much tighter now. Took it for a spin and the violent shaking is now gone, though it does shake ever so slightly.
    Color me embarr***ed and very thankful to have access to a forum like this.
    2Blue2 and panhead_pete like this.
  3. Nelson Clapp
    Nelson Clapp
    Great discussion! I am having the same problem with my '53 Plymouth (recently installed a B/W overdrive). I'll update after we find /solve the problem.
  4. panhead_pete
    panhead_pete
    Another awesome outcome!
