1st project
Discussion in 'The Hokey Ass Message Board' started by droopy, Apr 11, 2007.
  1. droopy
    droopy
    hey yall,
    i am starting my first project and am rounding up parts. i have got a 35 plymouth 5 widow coupe with factory frame and front axle,chevy 10 bolt rearend.i have purchased a 303 rocket with 2 speed hydramatic in a rolling 50 olds frame,body has been removed. i would like to hang drivetrain in 35 frame.any advice?
    all comments are welcome, thanks in advance
  2. Frosty21
    Frosty21
    from KY
    Are you going to be running fenderless?
  3. HemiDave
    HemiDave
    from Austin, TX
    Post pics. Always post pics.;)
    Are you gonna be doing the fab work or farming it out? Gonna be shiney?
    Dave
  4. Pictures would help....
  5. Sounds like a good start, the mopar ch***is was good in 35, on the initial mock up I like to leave the starter exhaust generator all in place. can all be changed if needed but gives you a good picture of clearence problems. measure the two rear ends with the stock wheels in place. once again that can be altered with wheels and off set. or possible a different later rear end.
    I like the car solid on jack stands with the front clip removed, to mock up the engine and trans dropped in as a unit. always cut as little as possible and figure on taking them in and out several time and make each obstruction go away then move to the next.
    If that 35 has a ladder frame you can probably modify the Olds rear cross member. or buy one after market
  6. droopy
    droopy
    here are a few pics,i don't have it tore plumb down yet. i plan on running fenderless,i am doing it myself with some help along the way. i am always open to ideas and suggestions.thanks for your comments.
  7. droopy
    droopy
    back to the top
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Quite a project for a beginner. I admire your for***ude.
    You'll get lots of help here, just keep throwing questions at us till we wear down. I dont know if going fenderless on that style of body will look right. But of co**** we dont really know what picture you have in your head.
    Good luck! PJ
  9. i really like the full fendered look on these without hood sides. looks plain old mean that way. youve got a lot of work on your hands for sure but its gonna be well worth it
  10. monzadood
    monzadood
    looks like a killer 1st project.
