2.5" Rams Horn Exhaust...are they worth installing over headers?
Discussion in 'The Hokey Ass Message Board' started by Buzznut, Jun 18, 2009.
  1. Buzznut
    Buzznut
    I've had my share of headers over the years, and though they may breathe better, I'm tired of the leaks and the excess heat. Seems as though every pair I've had came loose no matter if I double gasketed them or used "locking" bolts, and the underhood heat was excessive. From what I've heard about the 2.5" Rams Horn cast manifolds that were used on the old smallblock Chevy's they seem to flow well and don't bust a gasket or need retightening too often, and heat is lower due to being thicker cast iron. Anyone here used them or know anything about them?
  2. junkyardroad
    junkyardroad
    from Colorado
    I have had the same problems. For the SBC in 54 Ford, I couldn't find any rams horns around here so I went with manifolds off a 70's pickup. The easiness was worth any power trade off.
  3. Buzznut
    Buzznut
    I found them, just not sure it's worth the hassle of redoing the exhaust. I'm wondering if I'll notice a significant loss in power, and if they're worth $200...
  4. 35Chevy.com
    35Chevy.com
    from New Jersey
    I think most of the heat generated by headers is caused by the length of the pipes.
    It would be my guess that in most cases you wont notice any difference in performance unless you have an engine that really needs to breath.
    Gary
    1Nimrod and vtx1800 like this.
  5. I think 35 Chevy is right.
    vtx1800 likes this.
  6. Buzznut
    Buzznut
    It's a small journal '67 327 running 10.25:1 compression and I believe either the .268 or .289 cam, a 68 Z28 hi perf manifold with a 4bbl 650cfm and 202 fuelie heads....
  7. rainh8r
    rainh8r
    The new 2.5" manifolds from Speedway are $60 ea and seem to work well for me. You do have to cut off the generator bracket if you aren't using it, but it only takes a few minutes with a saw and grinder to make them look good.
  8. Buzznut
    Buzznut
    I saw those for $59 in the Speedway catalog...that's a great deal. I called them and it seems that shipping most anywhere in the U.S runs around $25 to $35.
  9. check your local chevy dealer. last ones i purchased were from gm out of oregon
  10. ruquik
    ruquik
    Why not the Sanderson Iron manifolds?? Other than the cost :eek:.
    1Nimrod likes this.
  11. Salty
    Salty
    from Florida
    Do a search on sanderson....I found it enlightening
  12. Al Napier
    Al Napier
    from Central CT
  13. Buzznut
    Buzznut
    I'm not sure why the Brzezinski guys at the link above are charging so much more than Speedway for the same manifolds, and I wouldn't pay $75 to have them match the ports...I'd just open them up myself.
    1Nimrod likes this.
  14. hotrd32
    hotrd32
    from WA
    It's a lot about the look I think. These are 2.5 in. and I ran 2.5 in exhaust all the way back. I wish some one would make them without the damn brackets. I'm trying to find a match to this one.
    1Nimrod and arkiehotrods like this.
  15. Buzznut
    Buzznut
    Sanderson are $480 cast and $640 ceramic coated! Too rich for my wallet...
  16. Buzznut
    Buzznut
    The brackets are easy to cut off and grind smooth. For $59 from Speedway you can't beat 'em...
  17. hotrd32
    hotrd32
    from WA
    Yeah, I did that on one set but it changed the texture and I didn't like the look.
  18. bunch of options....but do the vette one's flow as well as a set of headers? kinda wondering the same thing before i sneak to my dad's house and steal a set....
    planning on a mild blown 355 SBC... steal manifolds from dad = free.....buy headers = $$$$
  19. VespaJay
    VespaJay
    Yup, I did that to my pair, and detailed them up a bit with the grinder too. Got them from Riley Automotive, he's an Alliance vendor and Speedway dealer.
  20. bob3757
    bob3757
    from Tigard, Or
    Attached is a picture of a set from Speedway that I cleaned up . I bought 2 right side manifolds, & cut the bracket off of 1, to use on the left side. They come in a Dorman Box, but I don't think you can beat the Speedway price. Bob
  21. I think you can fix that with dryer sheets:)
  22. But seriously folks; if you gotta ask if headers make more power than manifolds, then you probably don't need them. I think the breaking point is in the cam, but let me tell you that even a stock motor digs some headers(and a curve kit). The thing about making them not leak is in the details, and if I told you I'd haf ta,,,,,,,,,,,,,,,
    gary macdonald likes this.
  23. Herdez
    Herdez
    I have early 2 inch rams to give it the old look. I did however port them out cause I didnt wanna loose any perf. from the switch. They now measure 2 1/4 outlet
    Instead of getting the 2 1//2's you can pick the 2s at almost any yard for old cars and with a lil time & porting would probably flow better than (clone) Corvette 2 1/2's. Some of those clones arent realy 2 1/2 so make sure your payin for what you ordered.
    If you dont want clones Hooker makes 80's factory style Corvette tuned rams in 1 3/4 -3 inch outlet versions that look good. part #2061hkr from summit.
    1Nimrod likes this.
  24. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Been on the fence between block hugger headers and ram horn's too. Headers for me have always been the same deal; loud and bolts backing off.
  25. dgc15
    dgc15
    I used stock GM 2 1/2 rams horns. I cut the mounts off and polished them. Had them coated by Air Born. They look good and work great. Bolt them on with the high heat silicone and no gaskets. Been on about 1 1/2 years with no leaks.
    1Nimrod likes this.
  26. GassersGarage
    GassersGarage
    There was a recent article in one of the mags which stated that there was no power improvement between ram horns and block huggers. You would need full length headers to see a benefit. There was a company that sold extrude honed rams horns but I lost track of them.
    bchctybob likes this.
  27. atomickustom
    atomickustom
    This leads me to a question I have been pondering: Couldn't I make a set of tubular manifolds? (Not exactly headers, more like a steel-tube version of the Speedway "tru-ram" manifolds.)
    They'd look cool, be cheap to make (do it all myself), and I'm guessing I would not have more heat than iron manifolds because the surface area would be about the same?
    If anyone can tell me why this would be a good or bad idea, please let me know.
    Otherwise, I'm also going to go with the factory manifolds.
  28. Solidaxel
    Solidaxel
    That is about the same specs as my 65 327 350 HP Corvette Coupe and it came with ram hornes and it still runs great all the way up to 6000RPM. The only thing i would do with them is grind them smooth and have them cermic coated and you will love them
  29. missysdad1
    missysdad1
    In my humble opinion the only time you need to be concerned about exhaust flow is at wide-open throttle at high rpm.
    99.9% of street driving is done at low and moderate engine speeds.
    Most cast iron manifolds, especially well designed ones like Chevy rams horns, are plenty adequate 99.9% of the time, they don't leak or produce anywhere near as much engine compartment heat as headers.
    So... If you're a racer (or a wannabe racer) headers might make sense.
    But if your rod or custom is primarily street driven, save yourself the hassle and go with cast iron manifolds.
    Just my $.02
    1Nimrod likes this.
  30. 65stepside
    65stepside
    i had 2.5 rams horns in my 65 p/u w/ chev 400 thing pulled like a freight train
    never leaked and they were on there for 12 years did grind the bracket off and it was noticable but that may have been due to my skills more than anything
    i did swap to long tube headers truck louder now also leaned out the carb so headers do flow better but now i am always tightening replacing gaskets
    if you just want to drive it and with less upkeep i think u would be happy with the rams horns
    but if you get an old set look for cracks they meet at the outlet
    1Nimrod likes this.
