$2.50 a lug nut!?!?!?
Discussion in 'The Hokey Ass Message Board' started by adamshumard, Jul 31, 2012.
  1. I pick a few of them up off the ground at the you-pick and toss them in my wagon every time I go.
    But there is one lug nut I throw away - those expletive fake chrome ones GM liked to use with rally wheels especially on Chevy trucks in the 80s and 90s. They're just a steel nut with a stamped stainless cover on them and they always get munged up and soft when they get old. I've literally thrown them as hard as I can in whatever direction ensures they won't hit anything or be likely to be found again on removing them.
  2. 40FordGuy
    40FordGuy
    Shop around....it does pay !
    4TTRUK
  3. 56don
    56don
    Do they have to be new? I might have some used ones.
  4. Biscayner
    Biscayner
    from MN
    Don't laugh at the prices sometime. I had 2 bucket loads of GM lug nuts from cars in the 70's and 80's SAE and Metric chrome ones from Firebirds and Camaros and other GM cars. I was getting up to $15 a piece for these as GM don't make them anymore and they are hard to find. Sadly the buckets are close to empty now, but the free meals I got off the sales were worth it. Wished I had saved more of them.
  5. continentaljohn
    continentaljohn
    You know the new lug nuts are missing10- 20% of the threads as well in the taper area. As they call it lead-in.. Also they are using a larger tap so its got more play or slop in the threads. . So the next time you use a old one com pair the old with the new . :rolleyes:
  6. notrod13
    notrod13
    from long beach
    better not own a toyota tacoma 6 lug.... they are special thread not US not Metric and cost 12.50 each x6x4=???
  7. WaynesSpeed
    WaynesSpeed
    I sell stock open ends for .75 ea, chrome closed ends are still only 1.25 ea
  8. are you serious? is this really pertinent? somebody lock this ****.
  9. RadioFlyer
    RadioFlyer
    Why? You don't use lug nuts on your ride?
    Alex.
  10. WaynesSpeed
    WaynesSpeed
    Don't read it, its not that hard
  11. S_Mazza
    S_Mazza
  12. Ranunculous
    Ranunculous
    That's great to hear! Those "Made in Chinuh" lugs scare me...I've seen the threads spiral out of the core like drill shavings.
  13. Atwater Mike
    Atwater Mike
    I hadn't bought any in a while, so when I went to my NAPA store and got socked for $1.00+ each for standard, open end 1/2" SAE Ford lug nuts, I almost shat.
    I found this thread most pertinent and informative. Thanks to all who shopped around and shared.
  14. It's like luke warm beer on a hot day in the desert, can't stop.
  15. I picked up 20 1/2 X 20 chrome acorn lug nuts brand new at the Jefferson swap meet in April for $10.00. .50 cents each. The guy sells brand new steel wheels, center caps, and trim rings in Wheel Vintiques boxes. He had boxes and boxes of lug nuts.
  16. HellsHotRods
    HellsHotRods
    $1 each for new chrome ones at the swap meets around here.
  17. iamben
    iamben
  18. Russ B
    Russ B
    This morning, I ended up paying $1.50 each for ten (1/2-20's, standard) out the door at a nationwide autoparts chain store, but I needed 20 and they did not have that many in stock! I guess it is understandable that most folks buy all they can by Internet. The parts store guy wanted to have a year and make to look up the part number! They did not like "1929 Ford" for their computer.
  19. 1946chevytruck
    1946chevytruck
    from london ,ky
    i paided $3 each for my lugs plus had to order them at the local parts place and go up their about 10 times
  20. Be careful. Just because the threads are the same doesn't mean that the seat angle is correct for the wheel you're using. Use a blue or red Marksalot for a little experimenting and make sure that all of them are the same type/weight on each wheel.
    Chuck
