2.75 r&p gears for a 9 inch ford rear?
Discussion in 'The Hokey Ass Message Board' started by Tim, Oct 26, 2011.
  1. Tim
    Tim
    from KCMO
    Hey guys,
    After some number crunching I decided that I'd be happy with a 2.75-ish gear ratio for this ford 9 inch rear im rebuilding for my tudor.
    however I've yet to find anyone to offering this ratio? is it just such an odd set that they just dont list it?
    or is there some terrible effect of running that gear that im not aware of?
    thanx guys
    timm
  2. squirrel
    You have to find them used. They're not as easy to find as they used to be. They were installed in lots of big ford cars in the 70s.
    I've put a lot of miles on the set I have in my blown big block 55 chevy
  3. RAY With
    RAY With
    Try the ebag NASCAR sellers and you will have better luck with the odd ball gears. I just purchased a 301 for 9 inch.
  4. 2.86 are available new from Summit. There used to be a lot of 2.49 to 2.75 from Versailles out there used since everyone pulled them out of those rear ends.
  5. bulletproof1
    bulletproof1
    from tulsa okla
    i just looked at 3 pumpkins 2 were 3:00 and a 4:20..none id use in a street car,,,...
  6. lukey
    lukey
    Many 77-79 1/2 ton ford trucks had them (2.76 i think) i have thrown out a few sets, now wishin i hadnt!
    -LUKEY-
  7. Ghost28
    Ghost28
    I have 3 sets of 275 gears. I am using one set in a 28 chevy and the other is being used in a 27 chevy and the other is undecided at this time. two sets came out of lincoln versaille housings and both are 28 spline non posi. The other came out of a 1980 mercury monarch also non posi 28 spline. There still out there.
  8. railroad
    railroad
    Grew up with a 67 LTD Galaxie 390 4v auto, had 279 gears, I think, They were 270 something. That should be close enough. If you don't find used, Randys Ring and Pinion can get any ratio you want and fast. If you do not need high priced gears get World Brand. I am running them in my T Bucket and they are fine. If you want better gears try Yukon. Randy can guide you on this stuff.
  9. whiskerz
    whiskerz
    from Ga.
    that was the gear in my 67 merc seems like it should be an easy junkyard find
  10. Tim
    Tim
    from KCMO
    hmmm, alright thanx guys :)
  11. fordor41
    fordor41
    I have a '70 Torino/9" with 2:73's
  12. Deuce Roadster
    Deuce Roadster
  13. Verminator
    Verminator
    I'm running 2.75 9" in the 55 panel with 265/70-15's on the back -- great highway gears without an overdrive trans. I swap in a 3.25 posi pumpkin for towing during race season.
  14. hotrod428
    hotrod428
    the 2.75 and the 3.00 are the most common stock ratios used, they are the one that get thrown away.
  15. 1949 caddyman
    1949 caddyman
    from arizona
    I have 2.50 ratio 9" gears in my 49 cad, got them out of a 1977 Tbird.
  16. pitman
    pitman
    I ran a 3.08 rear w/~28" tires for many years. A recent build had the 2.79 ratio, found it to be too tall. Long winded is nice but you can overdo it.
  17. Hooley
    Hooley
    Tim,
    Try to find someone in your area that builds rear ends for stock cars, drag cars. Chances are they have bought the 9" rear ends up for the housings. The high gears are normaly in good shape. Or ask the salvage yards who has bought up the rear ends. They are eager to sell the tall gears. I have run these tall gears for many years. In the Bonneville car we run a 2:49 Ford gear with no problems.
    Good luck
    Hooley
  18. Craigslist.com, Baltimore, MD auto parts, today. 9" 3rd member for $100. Might be pricey to ship, though.
    RB
  19. Richmond gear shows 2.8 available new for 9"
