1952-59 Ford 2 Barrel Carb question
Discussion in 'Off Topic Hot Rods & Customs' started by Joe-Racer, Aug 8, 2011.
  1. Joe-Racer
    Joe-Racer
    Hey guys, I just snagged an Offy 3x2 intake off of eBay for my 55 wagon. My questions is will the 2 barrel that is on the wagon now (stock 272) work as one of the 3 carbs that I'll need to make this this setup work?
    Thanks!
  2. sircampsalot2
    sircampsalot2
    are the other two carbs the same as the one on your car now?
  3. Ole don
    Ole don
    If you use the old 272 carb as the center carb it will run the same way it does now so long as the setup has progressive linkage and it doesnt leak on the ends.
  4. Joe-Racer
    Joe-Racer
    "are the other two carbs the same as the one on your car now?"
    I don't have additional carbs, just needing to know do I need to buy 3 or 2 to make the setup work.
    Thanks!
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Just buy two and you should be good.
  6. Ole don
    Ole don
    The end carbs can be different from the center, but the ends should match. I had a 327 truck carb on the center of an olds, and 283 carbs on each end. It ran as good as the stock J2 setup.
  7. Joe-Racer
    Joe-Racer
    Thanks guys! Now, I'll just have to keep my eyes peeled for the rest of the pieces.
    Thanks again!!
  8. 4oldfords
    4oldfords
    from Texas
    i should would like to see/read about how you get it all hooked up. this is something i may plan on doing in the future. thanks
  9. Retro Jim
    Retro Jim
    As long as the 2 outer carbs are the same size you will be fine . Rebuild both outer carbs with the exact same parts , seal off all the fuel adjustments on the cars and the vacuum holes , remove the chokes all together . Now get a 3 x 2 carb linkage set up and hook them up . The outer 2 carbs should be set to open at about 65% of full throttle . The center carb is the ONLY carb that should have any adjustments at all . The outer 2 carbs are just fuel dumps !
    That's all there is to is .
    Jim
