2 barrel carb riser
Discussion in 'The Hokey Ass Message Board' started by wickedfastrides, Jun 21, 2013.
  1. wickedfastrides
    wickedfastrides
    from colorado
    Anybody know where I can get carb risers for a Rochester 2gc ? I have a 4 x2 manifold that I want to bring the carbs up higher on. The carbs and the manifold are 4 bolt . Thanks
  2. Tony
    Tony
    I dont know where they can be bought, but they can be made fairly simple with a chunk of aluminum. I made some years ago for a tri-power i had.
    If you dont have access to a mill, a local machine shop should be able to whittle them up for you.
    Tony
  3. daliant
    daliant
    Hell, even a local carpenter could whittle them up for you, hardwood makes good carb spacers.
  4. Deuces
    Deuces
    .... And the wooden ones help keep the carbs cool from the engine heat...;)
  5. hoop98
    hoop98
    from Texas
  6. Try ****ster here on the board. He'll hook you up. I got some from him.
  7. gasserjohn
    gasserjohn
    Dashman here on hamb......
    made these tunnel ram spacers&phlonic spacers as well.........
  8. Badrodder
    Badrodder
    I think Dashman has the on Ebay...........
  9. dashman
    dashman
    from Viroqua WI
    Here is one that we in aluminum. We make them in phenolic at 1/4" and 1/2" thick and aluminum starting at 1/2" up to 2" tall. I have made them up to 4" tall for some customers.
    Dashman's Hot Rod & Speed Parts www.dashman.net
    Here is a pic.
