2 Duece manifold for Flatty w alternator
Discussion in 'The Hokey Ass Message Board' started by 26 FlatRod, Jan 16, 2006.
  1. 26 FlatRod
    26 FlatRod
    I am building a '49-'53 Flatty and I am using an alternator mounted in the center where the generator normally is. Question is, what is the best 2 duece manifold and carbs to use with this setup?
    There is an Offy in Speedway for about $200, and that is what I am planning to get, but the first carb is so far back, I am afraid it will hurt performance to the front cylinders. Good price for a new manifold tho.
    Any suggestions appreciated
    -Dave Robinson
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Which Offy? There are two common Offy 2x2 - the Super Dual & Regular Dual - with the alternator, you should have room to run the Super Dual if you're concerned about the spacing of the front carb...for a driver, you probably won't be able to tell between the two...
  3. Stafford
    Stafford
    from N. Georgia
    I ran a regular edlebrock with 2 94's on my 3/8 x 3/8 it ran fine, but when I put three 97's on it that I got from Uncle Max man did that thing come to life. The 94's can be a little aggrivating because of the powervalves. Good Luck, Stafford
  4. flatoz
    flatoz
    reds headers also has a few different intakes to choose from and the experience in flatheads too.
    I have always run superduals on the street, and you can do so with an alternator if you want.
  5. Flatdog
    Flatdog
    Dave I ran a 3-2 and not off set 2x2 and alt fit up front.The best manifolds? NAVARRO!
