Hy Guys I have a good Schiefer Aluminium Flywheel (Pat. 2719438) with Bronce insert and need to drive it on a 1943 59Ab with a Toploader Tranny! (1939 inserts) i have two 10 Clutch Discs and two 10 Pressure Plates but its dont fit for this Flywheel.(to big) the disc fits exactly on the bronce plate! Enybody knows what for a clutch setup i need? 9??? 10 Disc 9 Plate? will Fit????? Maybe someone hade this clutch setup? im looking for this! Question two: the Starter ring have some rusty teeth! can i change it with a new or used rings? enybody have made this? i need tipps!!! Thanks Marco
If it uses three sets of two closely spaced bolt hole patterns then its one of the Long type pressure plate styles. If it has 6 evenly spaced bolt holes as a pattern then it's a Borg & Beck 10-inch. It seems like somewhere on this board there are measurements between bolt holes for the 9-inch, 10-inch, and 11-inch Long type clutches. It also might be on the Certer Force web site. If its for the older pre-war and wartime engines it could be set up with a 9-inch pattern. Most of the later pre-war and wartime engines had the 10-inch but with Shiefer, it could have been set up to fit the early V8s with the 9-inch clutch. The flywheels are about the same and will interchange within the engine types with the bell housing as part of the block. Kerby
