Hot Rods #2 gauge wire for a 72" battery cable??
Discussion in 'The Hokey Ass Message Board' started by oldfart, Aug 30, 2014.
  1. I need a 6' battery cable for my wagon.Is 2 gauge the correct size or do I need 1 gauge?
    The engine is a 400 SBC and I have no accessories IE A/C,power windows etc.
  2. tfeverfred
    tfeverfred
  3. Deuce Daddy Don
    Deuce Daddy Don
    Use welding cable---I did!
    loudbang and SanDiegoHighwayman like this.
  4. Hello Oldfart,
    That #2 will work perfectly for that distance.
    Bill
  5. Hotrodmyk
    Hotrodmyk
    Welding cable is the bomb...plus...it is very flexible and easy to route around the ch***is.
  6. 325w
    325w
    Add grounds using the same cable.
  7. TomT
    TomT
    #2 welding cable will be perfect - I have used it in my avatar, my 40 coupe, and my 40 p-up project. You would never know the battery is that far away from the engine ....
  8. tommyd
    tommyd
    from South Indy
    Most Farm stores carry welding cable in bulk and sell the ends as well.
  9. tommy
    tommy
    Yes welding whip cable. Have them crimp the terminal on the cable.
  10. Ebbsspeed
    Ebbsspeed
    I'd be highly tempted to go to a #1, or maybe even a #0. How much current does a starter draw when turning over a 400ci V8? Kinds depends on compression ratio, temperature, etc. but I don't think 200 or more amps is beyond reason, especially considering that the minimum recommended battery rating for a lot of vehicles that the 400 came in is 540 cca. #2 seems kinda light to me. It'll probably work, but you'll have a lot less voltage drop and faster cranking with a heavier cable.
    But then again, I only studied this stuff for four years in college to get that BSEE degree, so what would I know?
  11. roundvalley
    roundvalley
    Go to Ebay and buy some 1/0 for $3 @ foot. Red or black.
  12. 270dodge
    270dodge
    from Ohio
    I used #2 welding cable back in the day for 3 years of daily driving (383 Mopar with trunk mounted battery) no problems.
  13. 270dodge
    270dodge
    from Ohio
    Oh well, I probably use the keyboard faster than I think. I use #4 as a whip cable on my Miller ABP 300 welder and have used it at 400 amps for quit a while. the cable becomes noticeably warm after 3 of 4 rods are burned. I really doubt that the cheby starter would live under the amperage attack. # 2 or #4 is safe.
  14. oldsman41
    oldsman41
    farm and fleet or tsc has the welding cable in reels just get what ya need
  15. bobss396
    bobss396
    Sumitt has a nice cable selection too. NAPA may even have it on a reel.
    Years back when I was building my Nova stock car, I ran into some heavy gage aluminum wire at a s**** dealer. It worked just great no matter how hot the car got if I had to restart it.
