Hot Rods 2 Holley 2100 carbs on y block?
Discussion in 'The Hokey Ass Message Board' started by Lucky chop shop, Jul 6, 2019.
  1. Hi everyone, I was wondering if anyone had put dual Holley 2100 carbs on a 292 y block? If so what intake would I need?
    Thanks
  2. jimmy six
    jimmy six
    Any dual quad with adapters, any 3-2's with 1 block off or a single 4 barrel with one of those y looking adapters.
  3. AldeanFan
    AldeanFan
    Why would you?
    Mr48chev and jimmy six like this.
  4. Blues4U
    Blues4U
    from So Cal
    Why not? Because he wants to is good enough reason.
  5. AldeanFan
    AldeanFan
    Unless I had two free working carbs and a free 2x4 intake I would stick with a single 4.
    Mr48chev and Oldmics like this.
  6. miker98038
    miker98038
    Part way down the list you’ll find the testing on 3x2 and 2x4 manifolds. Poke around a bit and you’ll find comparisons on aftermarket and stock 4 barrel intakes. Might give you some background to try jimmy six’s suggestions.
    His setup is real nice, and if he’s who I think he is, it’s better with the air cleaner on.
    http://www.eatonbalancing.com/2000/03/24/quick-index-for-eaton-balancing-articles/
  7. egads
    egads
  8. Here’s what I’m think dual Holley 2100 94’s dropped into a vintage speed “y adapter.” That has 3 1/4” x1 7/8 four bolts. So what adapter would I need to go from 3 1/4” x 1 7/8” to the y blocks larger 5 1/8” x 3 7/16”?
    I could also use speedways vtg. 2 barrel
    I really need help figuring this out further help is greatly appreciated
    I’m not really building a performance engine, just want to have something fun and cool looking. So you guys know it in my 31 model a
  9. Blues4U
    Blues4U
    from So Cal
    egads likes this.
  10. I can do the work myself just need a little help with the “what parts fit what” stuff. He makes some cool things, very well put together. I don’t exactly have an unlimited budget. I’m kind of “backyarding” this.
  11. Do you know if there’s such a thing as a 4 bolt 2 barrel to larger 4 bolt pattern adapter. Or a 4 barrel carb to 2 barrel intake?
  12. clem likes this.
  13. Mr48chev
    Seems like a hell of a lot of work to have a car that in the end won't run as good as it did with the single 4 barrel just to impress the mouth breathers.
  14. Blues4U
    Blues4U
    from So Cal
    He's also a source of parts and information about what you're looking to do.
    egads and Texas Webb like this.
  15. clem
    clem
    True, and the cost of adaptors are probably more than a used 4 barrel, but,
    1: It will look better.
    2: He will learn a lot doing this.
    3: Some of us view these sorts of things as hot rodding.
    4: It’s his car !
    I’ve put 3 x ‘94s (actually 1&1/16” - fixed linkage originally) on my 283. Most said it couldn’t be done, yet wouldn’t say why, or offer helpful suggestions, so I read all of dreddy bears links on here pertaining to 94s and away I went.
    Blues4U and Boneyard51 like this.
  16. Exactly how I feel!
    clem likes this.
  17. AldeanFan
    AldeanFan
    Whatever you do please post pics, I want to see this!
  18. clem
    clem
    With a Y manifold, you could run progressive or fixed linkage.
    Fixed linkage is probably the better/easier way to go, whatever you decide.
    egads likes this.
  19. I’m going with fixed linkage parts are ordered and on the way! Sadly the fellow I bought the carbs from is on vacation until the 31st! So it will be awhile until it’s totally put together.
  20. egads likes this.
  21. clem
    clem
    Now there’s a good idea !
  22. So here’s what is happening. I ordered a y adapter for the carbs
    [​IMG] just need to make an adapter to the y blocks bolt pattern shouldn’t be too hard
