2 Lane Blacktop & Adam 12 Connection
Discussion in 'The Hokey Ass Message Board' started by LM14, Jun 19, 2013.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Who won?, the show featured Dick Clark as the track promoter and Gary Crosby (Bings baby boy) as Ed Wells and the antagonist of Reed and Malloy in the Camaro.
    As the story goes the Chevy was suppose to have a problem in reality Gary really did break the car. HRP
    Written by Phil Burgess (National Dragster Insider)
    "This is Ted Wells' 1954 Ford. This car was unique. I raced with Ted from about 1969 until 1974. Ted was the shop foreman at Larry Orfia's Valley Head Service (in Tarzana, Calif., two doors down from Frank Huszar's Race Car Specialties shop). I spent a lot of time hanging around VHS and RCS in those days, much to the detriment of my college education. Teds car was originally powered by a 352-cubic-inch big-block Ford. This was later changed to a destroked 427 big-block Ford; actual displacement was 396 cubic inches. Ted was a master machinist and fabricated a lot of the parts on this car. He fabricated a custom aluminum tunnel ram intake manifold simply because at the time there were none available for a big-block Ford and partly because he liked a challenge. He also molded the entire fiberglass front end himself. This car weighed in excess of 3,800 pounds. It would launch so hard that it literally would pull the pinion carrier out of the third member on the 9-inch Ford rear end. To fix this problem, rather than changing to a Dana rear end (which was in vogue at that time), Ted fabricated a custom third member out of 4130 steel plate that he welded and machined himself as there were not any other options available to be purchased if you wanted to run a 9-inch Ford rear end back then. He also ran a Ford top loader 4-speed transmission that he had modified to the point where he NEVER missed a gear-change shift! This car ran consistently 10.70s, which was very fast for that era. In 1974, Ted was working on building a Super Stock 427 Fairlane, although I am not sure if he ever completed this project as he moved to Wichita, Kan., and I lost contact with him."
    Tickety Boo, bowie and Kelly Burns like this.
