2 Oldsmobile questions 1959
Discussion in 'The Hokey Ass Message Board' started by Leroy 701, Apr 30, 2010.
  1. Leroy 701
    Leroy 701
    I have a 59 Olds 2dr ht and I was wondering if the front glass is the same as a 60 Chevy 4 dr sedan? They appear the same...but?
    I was also curious if a 394 4bbl intake could be used on a 371 motor, both 59 models. Thanks!
    Hamb rules
  2. 57J2
    57J2
    The glass is different, hardtops interchange and sedans interchange but hardtops will not interchange with sedans. The manifold will fit both engines.
  3. As 57J2 said, 59-60 GMs the hardtop and convertible use the same glass. The wagon, sedan, and El Camino use the same glass. The hardtop/convertible glass is about 2 inches shorter.
    The 394 intake should fit your 59 371 as I believe yours is the taller deck height that is same as 394's. Will not fit 57-58 371 which are lower deck height.
  4. Leroy 701
    Leroy 701
    So will a 4 dr ht fit with a 2 dr ht?
  5. 57J2
    57J2
    2 door Hardtop and 4 door Hardtop are the same.
  6. Leroy 701
    Leroy 701
    Thank you for the info, much appreciated!
