2 or 3 Carbs. on a 331 Caddy?? Opinions Please
Discussion in 'The Hokey Ass Message Board' started by Krash, Dec 6, 2011.
  1. nowaxn5
    nowaxn5
    Thanks for the info Barry. I have one of these set-ups and never new the reasoning for the center section. Good to know.
  2. Torkwrench
    Torkwrench
    Do the Edmunds intakes flow much better than the factory 2x4 intakes? Can newer carbs, such as AFB's (or the Edelbrock equivilents) be adapted very easily to the factory intake? I have a factory 2x4, without any carbs, and the price of actual dual quad WCFB's is kinda scarey.
  3. swissmike
    swissmike
    Does anybody know the CFM rating of the '49 single two barrel carbs?
  4. Dyce
    Dyce
    I've been wondering the same thing.
  5. carlitos way
    carlitos way
    cool and helpful stuff.keep it up i'm getting ready to swap my stock intake on my 53 caddy
  6. carbking
    carbking
    Carter did not publish CFM ratings on O.E. carbs until the late 1970's.
    Jon.
  7. go quad...
  8. Rocky Famoso
    Rocky Famoso
    I run two Rochester 2-G carbs on an Edmund manifold on my 289 Studebaker (mild build-up) with progressive linkage. The front carb is the primary with the idle circut and choke, the rear is a secondary (gutted). Same carbs as what GM used for their 3-Deuce set-up. I had to re-jet to a smaller size because of running too rich. It now runs great, and gets it on when I punch in the secondary. I think what your going for with an early look (49-early50s) the 2-Deuce set-up would be more appropriate to the era.
  9. F&J
    F&J
    Actually, It is not a silly idea. A hamber posted up pics of a very rare (and unknown to most of us) 4 one barrel, logs for an early Olds. I thought it was silly until you do the math on cfm. Who knows how 8 would do, but give it a try. I would think you need small one barrels..but..:confused:
  10. falconsprint63
    falconsprint63
    from Mayberry
    I vote 3 x 2. had a 2 x 4 myself and sold it in favor of the 3 x 2.
  11. callcoy
    callcoy
    I personally think the the vintage look would be 2 x 2, time wise this would be before the 3 X 2 were available. Some times less is more! The early rods I remember in the 50's had fresh from the wrecking yard "mills" cleaned up some even got a paint job. The early rodders sometimes used all their money just buying the used engine and trans adaptor. Your project brings back memories!
  12. Krash
    Krash
    from Cleveland
    Thanks for all the help!
    I am leaning toward the Offy 2x2 intake because of the style and period I am after.
    Problem is I have a factory '59 Caddy tri-power sitting on it now....and 3 carbs sure look good on the top of that long *** engine.
    I am the most indecisive person on the planet!
  13. F&J
    F&J
    If those are real tripower end carbs, I'd use them for sure. A real 3x2 will outperform a 2x2 on all issues, and no fighting the idle issues that "might" happen with 2x2. If you get even a tiny bit of slop in the 2x2 connector link, you can be idling on one carb, and not know it.
  14. donnie gt
    donnie gt
    whatever makes it good for you!
    2 x 2' s are nasty looking but eat the go go juice...3 x2's look neater in my opinion, don't overfuel as bad and if you stay off the go fast ****on get far better fuel economy, as is anybody cares about that!;)
  15. if you can find an intake. for me, 2-wcfb carters would the way to go.
