2 part drive shaft advice
Discussion in 'The Hokey Ass Message Board' started by Ohmboy, Feb 25, 2009.
  1. Ohmboy
    Ohmboy
    from Dallas
    Hey guys, I am modifying my 60 olds by mating a modified 700r4 to the 394. THe drive shaft will need to be cut down, but its a two piece drive shaft. Looks simple enough to handle, but would it be better to swap the whole thing out for a single drive shaft?
  2. brigrat
    brigrat
    from Wa.St.
    I am doing the same thing to a '64 Impala SS and would also like to know if I can make just a one piece? Seems the frame center section might not let a single shaft travel enough up and down or that the drive shaft angle would be hinderd by it........... sorry dunno!
  3. Jobe
    Jobe
    from Austin, Tx
    Without major revisions to the x-frame I think you are stuck with a 2 peice drive shaft...but I guess anything is possible!
  4. skunx1964
    skunx1964
    i dont think you can do a one piece. ive got a 58 chevy and ive been going over driveshaft options also. mine binds when the wheels are hanging, no way a one piece would ever clear. check with a local drive shaft place, or online, like dennys driveshafts. im thinkin of goin with one like that. 3 inch aluminum, splined slip joint, hardmounted carrier. ive had problems with the flimsy carrier bearings shearing in half. ill be watching this thread
  5. R Pope
    R Pope
    Your Olds has the X frame, doesn't it? They need a two piece 'shaft.
  6. skunx1964
    skunx1964
  7. belair
    belair
    Don't think you can get there from here. GM used a 2 piece for a reason.
  8. Just get your drive shaft cut. I use a shop that does drive line work on dump trucks. The last one I had him do for me cost $15. He cut the yoke off cut a couple inches out of the tube and welded it back in on his lunch hour. That was a while back may cost more now but for a few bucks your problem is solved. Just be sure of your measurement's.
  9. shemp
    shemp
    Alliance Vendor
    The Chevy 2 pc. drive lines are very small diameter. After twisting many of the originals, I found that a '62 Falcon drive shaft was just the right length. I cut a notch in the bottom of the frame, and opened up the center web a little. I would recommend fabricating a reinforcement for the bottom of the X. Never had another problem with the drive shaft, of course it now broke spider gears and axles.
  10. skunx1964
    skunx1964
    what the hell are you runnin in that thing?
  11. shemp
    shemp
    Alliance Vendor
    Unfortunately, I sold the '62 about 15 years ago. It started out with a 300 HP 327, and progressed to a 409 I built out of someone else's left overs. I used to drive it very "aggressively" . 6 grand clutch dumps are very hard on parts.
  12. skunx1964
    skunx1964
    my 58 has a healthy 355 and im always killin th350s and carriers. once those are built good, then itll prolly kill the rear, lol
  13. Ohmboy
    Ohmboy
    from Dallas
    THanks guys - I think Evil-Wicked... has the right idea. It will be a lot easier to cut down the original shaft. And since it is an X-frame, I would have to modify the frame to account for the 1 piece shaft and the angles would be in question. Its amazing this design works as it does. thanks again.
  14. millsryan
    millsryan
    I read a long long time ago in Lowrider Magazine (I know I know... I was in Iraq and had very few things to read) the horrors of guys trying one piece driveshafts in x frame cars. Not only is the distance too long, you have imbalance issues, u joints that are too small to handle that distance of shaft and clearance issues. Also get the awsome neoprene encased carrier bearing. Way better than the loosey goosey rubber p.o.s.
