2 PCV valves
Discussion in 'The Hokey Ass Message Board' started by sixbangr, Aug 4, 2010.
  1. sixbangr
    sixbangr
    My 302 is shoving oil out of the breather. Is there any reason you can't put a pcv in both valve covers?
  2. medicinal_marinara
    medicinal_marinara
    from Oregon
    You shouldn't be shoving oil out unless the baffles are bad or missing.
  3. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Yep Its designed to **** air from one side of the motor and then burn it off through the carb from the other side .Positive crankcase ventilation .Sounds like your rings .,,Or breather isnt baffled and your oil is shooting into your breather , If its an late model 302 with aluminum factory valve covers ,Its your baffle ,Well lack of one.....Late model I mean 87 and up....
  4. onlychevrolets
    onlychevrolets
    I agree...sum'n is wrong
