2 Questions, deleted post, and private conversations
Discussion in 'Questions & Suggestions' started by Willys2point3, Dec 1, 2020.
  1. Willys2point3
    Willys2point3
    Hi, I was attempting to start a private conversation with an admin to discuss a post that was deleted, but I also do not appear to have the ability to start a conversation. I'm not sure if that is a limitation on a new user or what the deal is?
    I'd still like to understand why my post was deleted, so if an admin is able to start a conversation with me that would be great!
  2. grumpy65
    grumpy65
    Check out the forum rules. They are very specific and straight forward. I'm sure if you read them you will be able to work the reason out for yourself. Not having a go at you. Just some friendly advise on how things work around here.
  3. lothiandon1940
    lothiandon1940
    If you were talking about your '42ish Jeep or '90 Volvo that may be the issue. Neither would be considered a traditional hot rod or custom.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    lothiandon1940 likes this.
  5. wraymen
    wraymen
    The 42ish Jeep would be acceptable on the antiquated section. :)
  6. lothiandon1940
    lothiandon1940
    ..........Good point.
    wraymen likes this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    he is talking about the deleted for sale ad for a pinto bellhousing. not on topic anywhere here
  8. Willys2point3
    Willys2point3
    Yeah, I signed up because I had read a few threads on here from others adopting the Ford 2.3 into an old hot rod. I searched this site quite a bit when starting my build. My situation is essentially the same even though my '42 GPW is 4wd. That particular bellhousing is in some cases a key component for adapting that engine to a vintage transmission. It has a short 7" depth which allows space for an adapter plate and retain the original input shaft on the transmission. I thought it may be useful to someone here, as hot-rodders and a handful of flat-fender jeep guys are the only ones doing such a conversion these days. Apparently I was mistaken, so I can be on my way.
  9. What's this pinto you speak of? o_O
