Technical 2 speed powerglide wont go into second gear
Discussion in 'The Hokey Ass Message Board' started by Harleyv89, Feb 28, 2023.
  1. Harleyv89
    Harleyv89
    The worst part is i dont exactly know what to look for but the linkages how lower then my ch***is and that doesn't seem right
  2. 427 sleeper
    427 sleeper
    I thought it was eliminated in '63 when they went to aluminum cases.
  3. Harleyv89
    Harleyv89
    Apparently they had a rear pump until 1967
    jaracer likes this.
  4. Budget36
    Budget36
    It’s a mechanical device. If something is amiss when you are looking at it while it’s being moved, I’m sure you spot it.
    The key is having your partner telling you “I’m moving it now, etc”. Then if he/she is moving it and you see nothing moving, you can start zeroing in on things.
    As mentioned, if you disconnect the linkage, you know if it’s in the transmission or the shifter and where to focus your efforts.
  5. Harleyv89
    Harleyv89
    I got my partner to shift through the gears and it seems the linkage on the gear box moves with the shifter on the column but it has alot of play in the shifter on the column, i have also noticed from park there is one click and its in reverse then another click and im still in reverse?
  6. Harleyv89
    Harleyv89
    Hi everyone so went through the manual and apparently the linkage on the gear box was wrong, according to the owners manual low gear is when the lever is all the way towards the front of the car is that correct? Can anyone confirm that?
  7. Harleyv89
    Harleyv89
    That is where the shift lever sits when in park is that correct?
  8. Budget36
    Budget36
    I’m not sure where it supposed to sit, but I don’t think the General put a hose clamp there.
    I’d take it off and see what it was trying to do.
  9. Harleyv89
    Harleyv89
    He definitely didn't and i kind of want to know the reason its there before i take it off haha
    Budget36 likes this.
  10. Budget36
    Budget36
    Might be evident when you take it off, ie your issue might get worse;)
  11. rusty1
    rusty1
    that hose clamp on column,...probly to take out slop on steering shaft...?
  12. Kevin Ardinger
    Kevin Ardinger
    If it ain’t park it must be low
  13. Harleyv89
    Harleyv89
    Haha it stays there forever
  14. Harleyv89
    Harleyv89
    Yeah its got abit of slop for sure
    thats the thing to different spots and they both are in drive i dont get it
  15. Harleyv89
    Harleyv89
    On the linkage on the gearbox is all the way to the front of the car low gear or park?
  16. X-cpe
    X-cpe
    Easy to find out. Put the shift lever on the trans all the way to one end of its travel and try to push the car. If you can't push the car, it's in park. If you can roll the car, it's in low. Or if it is on jack stands, just try turning the drive shaft. (parking brake off)
    lothiandon1940 likes this.
  17. Ron Emerson
    Ron Emerson
    It is a right hand drive Chevy right. It looks like it has a totally different shift and kick down arrangement than the states. Did you get a manual for a left hand driveChevy vehicles. The inside transmission should be the same. Also I think there is a split pin in front of the modulator inside the trans if you replaced the modulator the pin might have fallen out.
  18. 61Cruiser
    61Cruiser
    Hi Harleyv89, it looks like you have an Aussie ***embled rhd like my 61. I have a cast iron p/glide but the linkage at the column is the same. If you can wait until this coming Monday (20th) I’ll shot a little vid of mine going the the positions ( p,r,n,d,L) The linkage at the trans will be different on mine but it may help. Also, the hose clamp on the column before the coupling is a concern that you should look into. It could mean the bearing in the column is toast, or the coupling is toast. Is there a local Victoria Chev Club you could contact because these Aussie Chevy have some differences to their USA cousins.
    Cheers.
    sdluck, X-cpe and Budget36 like this.
  19. 61Cruiser
    61Cruiser
    Hi again, I’m sorry but I can’t seem to upload a video for you. Email me if you wish and I’ll send it to you.
  20. ClayMart
    ClayMart
    You'll first have to upload your video to YouTube. Then copy the URL for your video from YT and paste it into your post here to link to the video.
  21. 61Cruiser
    61Cruiser
    Ah, I see. I’ll give it a go. Thanks.
  22. 61Cruiser
    61Cruiser
    I’ve followed ClayMart’s tip. He goes
  23. Harleyv89
    Harleyv89
    Hi mate,
    yeah something is definitely not right with the steering column i need to get it looked at before i drive to far
  24. Harleyv89
    Harleyv89
    Super helpful video mate thank you
  25. Harleyv89
    Harleyv89
    Thanks everyone for the information it's appreciated, it turned out to be the clip on the govenor had broke thats all haha thank again. Next trick is to see what is going on with the clamp that has been put on the steering shaft before i got it
    saltflats and bobss396 like this.
  26. 61Cruiser
    61Cruiser
    Hi Harleyv89, no probs with vid. Just happy and try and help a fellow Chevy owner! With the column, take that clamp off and see how much moment there is in that coupler below the linkage, it should have only have minimal movement, it’s like a uni joint. I would guess that it’s a steering column bearing though. The guys at American Suspension and Driveline in Victoria should have them and they are good blokes to deal with.
    Cheers
    Mark
  27. bobss396
    bobss396
    The governor is one of the 1st things I will look at, some have a nylon collar that gets brittle with age and breaks.
  28. 38Chevy454
    38Chevy454
    Here's a test you can do, but BE VERY CAREFUL! With engine off, temporarily disconnect the shifter linkage. Turn the shift arm on trans from park 3 clicks (1st is reverse, 2nd is neutral, 3rd is drive). Now roll car into the street, start it WITH FOOT ON BRAKE. Now go for a drive and see if it shifts into second gear. If it works on this test, your linkage is the problem, not the transmission. Now reconnect the linkage and put back into park. Note that you will be starting the car in gear! Make sure you don't run into something, that's why I suggest pushing into the street. You also won't have reverse or any ability to change anything on shift position on the trans during the test. So only drive where you stay going forward.
    The shift linkage is just mechanical connections. Make sure you have tight connections. Adjust so column is coordinated with the trans shift position when you put it back on.
  29. Harleyv89
    Harleyv89
    cheers mate, the clamp seems to be stopping the steering shaft from going back in. The steering wheel itself can be pushed forward about 10mm. I believe after 1961 the stopped using wave washers and now have two bearing blocks with a spring between it so i am thinking maybe the spring is stuffed?
    427 sleeper likes this.
