2 UPDATES, 59 wagon, 32 fiver.
Discussion in 'The Hokey Ass Message Board' started by titus, Mar 22, 2004.
  1. titus
    titus
    we got a ton of work done o STEVIEDS 59 wagon, on fri sat and sunday, we: put on exaust, front shocks, sway bar links, cut 2 coils out of the front, 1-1/2 out of the rear, put a new starter in bat cables, rewired the entire rear end of the car, put front tires on it, primed the front clip and passenger side, put a new carb, cap rotor and plugs in it and made it rum correctly. so just a bit done!
  2. titus
    titus
    did that last pic turn out? looks*****py on my computer!
    any ways, i also got a bit done an the 32, i got the body back on so i could finish the steering and some other few miinor things, then back off it comes! heres an over all pic
  3. titus
    titus
    heres the column mounted, i fliped the shifter on the left side of the column, some old timers round my parts said they use to do that so their babe could get closer to em!
  4. titus
    titus
    here another pic of the wagon
  5. Looks kill bro!both of em.Lotsa work going on.I was too busy rippin around in my roadster......Shiny
  6. fab32
    fab32
    That '32 is really starting to shape up. Will you have it on the road this summer?
    Frank
  7. titus
    titus
    hopefully it will be, in primer of course!, my house refi went through and i ended up getting some cash back so i can afford all the necissary parts fo it, so i think i can do it.
  8. Stevie D
    Stevie D
    The wagon yes is looking good
  9. That 5 window is gonna be just right.
  10. Rolf
    Rolf
    That's my man! Refi the house to build your hot rod. Right on!
    What steering box are you using? Starter still on the left side or did you move it?
    Pix of your steering arrangement?
  11. katzenhammer
    katzenhammer
    Cool you made a Necker Shifter! Show more pics if ya got more of the set up. Did you use a Ford Column?
    Justin
  12. titus
    titus
    starters still in the same place, i used a nova (68-73) manual steering box (twin to a vega only bit bigger) the buicks have plenty of room where it goes so it didnt get in the way, i think this is the only other pic i have, i modified the stock 40 coloumn with a bushing in the end and change all the shift linkage so only the one lever worked, then use a gm style cross shaft from the trans over to the frame. with a lever off that for the rod coming from the column to go to.
  13. titus
    titus
    ill try to get some better pics later if interested, heres another pic i liked
  14. Rolf
    Rolf
    Aha, you put the box under the motor mount tab. I guess the lengt of the pitman arm dictates the location. Thanks !
  15. lucky_1974
    lucky_1974
    Shit man you are haulin**** on that 59 chevy. Looks good. Can't wait to see the 32 on the road. Talk to you later.
  16. Southfork
    Southfork
    Titus, since you offered, please post some more pics of the Wagon. Also, you're using a Switchpitch******* behind the nailhead in the coupe, right? So does the linkage off the steering column engage that ST-400******* correctly, or are you still debugging it? I'd like more details on that, if you'd care to elaborate.
