20" model AA Bud Wheels
Discussion in 'The Hokey Ass Message Board' started by rustiepyles, Dec 4, 2013.
  1. rustiepyles
    rustiepyles
    Anyone have any thoughts on how to bolt 20" Model AA Budd disk wheel to a 5 on 4.5" 9inch rear-end? The Budd wheels are 5 on 6.875" (6 7/8").
    My thoughts are to weld up the bolt holes in the wheels and redrill them on a mill with a rotary table.
    From what I can tell the patern diffeance is to great to use a wheel adapter, it will not spread the load properly.
  2. Jalopy Joker
    Jalopy Joker
  3. gimpyshotrods
    gimpyshotrods
    I forget if those are split, or not. Go for it.
  4. cb1
    cb1
    from Wisconsin
    When we race circle track, we had a plate that had different bolt patterns. Just bolt it on and drill the new holes. We used it to change ford axles to chevy bolt pattern. I don't think it went that big (5x6.875) though. Bought from a race parts supplier. Went away with the rest of the circle track stuff.
    cb1
  5. rustiepyles
    rustiepyles
    Not technically split but they do have a "snap-ring" bead.
  6. rustiepyles
    rustiepyles
    Yeah I thought about milling out a drill guide for them, but I came to the conclusion that making the guide on the same mill that I would drill the wheels on wouldnt really be any more acurite then just milling the wheels.
  7. rustiepyles
    rustiepyles
    I think I'm going to have to weld in a center hole reducer so I have a little more meat left between the new holes and the center hole. which should be no trouble since they have a shoulder on the back side in the center hole.
  8. I really love the look of those Budd wheels. I've got a '29 AA and changed over to a 1960 F-350 running gear (wheels, spindles, rear axle, brakes, etc.) just so I could come close to the look of Budds, but with the stout, later-model durability and higher cruise speeds.
    I'd sure like to see photos of the changeover: Before, during and after. Sweet!
